11-25-2006, 10:47 AM
#20
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
Originally Posted by Ondonti
I think the point is that 87turbodance wants to go to an insane amount of trouble to do a headswap but just slap a m90 on there.
Ive seen the M90 efficiency maps before and I would think its important to make sure you are going to stay in there.
You want to be in the 50% efficiency island of the m90.
Edit: I havent seen m90 maps before, just "other" roots blower efficiency maps. I dont know if the maps are available for the mseries.
I would like to do the head swap so that it is done. An M90 will be a stepping stone. I wouldn't be asking for anymore than 12psi from the M90. I think it should plenty enough air for 300WHP. The next step after the Eaton would be a turbo. I think there would be plenty of fun to be had with the M90.
The reason for the complicated head swap is to get a better starting base. I also like the broader powerband of the multivalve heads. Better for the street. I'm sure there is tons of power to be had from 12V heads it's just that right out of the startig gate you're limited by the head efficiency. I believe it is far easier to make power with 4 valves than 2. Two valves can make just as much power but you sacrifice driveability.
