Old 11-26-2006, 12:09 PM   #31
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
Id still go with a turbo myself. I considered a supercharger...in fact i was considering offer harvi a grand for his setup...he lives not far from me but ...i think a turbo will suite my needs best...i dont know about dusty.
irocelectric93 is offline
Old 11-26-2006, 01:40 PM   #32
My Ride: 1993 dodge daytona
Induct: S/C
Originally Posted by Ntrain2k
I would suggest you start off with the stock SC pulley and an UD crank pulley. Tune and work your way up from there.
Lots of fresh motors have been broken from running hella boost from the start.
i hope i do so i have an excuse to build a stronger one! i do plan on running a udp w/ 3in piping and a pretty big intercooler so i think i should be around 12-15psi. w/ a proper tune i think the stock motor can handle it but we will see.
m90daytona is offline
Old 11-26-2006, 01:43 PM   #33
My Ride: 93 LeBaron sedan
i plan on runnin non intercooled boost, how much not sure of but it willbe with an m90 similar to dan's setup
Boogieman142 is offline
Old 11-26-2006, 06:24 PM   #34
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Just remember that Dan was pre-detonating with his setup after the motor warmed up to operating temps. You're definately going to need to use a water/meth setup if no intercooler is going to be installed.
mwinkle353 is offline
Old 11-26-2006, 08:15 PM   #35
My Ride: 92 sundance duster
Engine: 3.0L 24v
^^+1 start low and move up.
(i hope an UDP and smallest SC pully will keep an M90 around 8psi, stupid detonation prone 24v :-p)
Shadow24V is offline
Old 11-26-2006, 08:35 PM   #36
Engine: 3.0L V6
I'd start with the largest SC pulley first. Then work the way down.
Old 11-27-2006, 02:22 AM   #37
Yeah, he usually drove the car with the underdrive pulley because it pinged like crazy with the higher boost. I would say its luck he didnt lose any pistons.
Old 11-27-2006, 01:47 PM   #38
Engine: 3.0L 24v
woops, yeah, larger SC pully lol
Old 11-28-2006, 07:05 AM   #39
i was debating on water injection but i just need to get it all working first
Old 11-28-2006, 11:43 AM   #40
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
I'm a real believer in water injection. Keeps the knock away so you can run full timing to keep your EGT's down
87turbodance is offline
Old 01-30-2007, 10:51 PM   #41
I took this picture to educate a supercharger retarded person who was arguing with me on another site.
I thought I would share this since I had talked about it before.
Obviously the m90 is not a 100lb/hr supercharger but you can see here how superchargers work and what happens when you increase blower speed etc. This is how a Roots map should look but I think companies hide this information (nobody knows why just like nobody knows why a T67 turbo compressor map is secret).
If this was a screwcharger imagine the center efficiency island being 85% or higher and the HP losses being 1/4 what they are on that chart.
So that means a 1000hp screwcharged motor would lose 15hp driving the supercharger, be more efficient (this term confused the person who i was talking about because they think the term efficiency when talking about superchargers/turbos is a combination of things rather then 1 specific measurement of heat added lol).........and have a powerband from near idle to redline!!!
The crappy thing about screwchargers is they are very expensive, and upgrading (rather then just overdriving it....you can see what overdriving does to superchargers in the chart) will cost you $5-15K depending on your setup. Also you might not be able to handle the insane torque (or your transmission might not be able to).
Old 01-30-2007, 11:19 PM   #42
If you look at this chart it should make you throw up when you think how unhelpful supercharger charts that companies provide are.
You can see here a BIG roots blower on a really efficient large motor can make 500hp and only draw 10hp from the engine.
Loans | Cheap Loan | Share Prices | Loans | Gas Suppliers
Page generated in 0.39805 seconds with 13 queries
