Old 12-04-2006, 01:50 PM   #1
differences of the A413 and the 670
My Ride: 1990 Dodge Spirit ES
Engine: 2500cc
I was wondering if the internals of the A413 would work with the 670 trans
TurboSpiritES is offline
Old 12-04-2006, 01:58 PM   #2
My Ride: Laser XT
Images: 1
you might as well get a rebuild kit instead of using old worn out parts, but I'm pretty sure they are the same besides the casing. The 670 probably has stronger internals also.
jory is online now
Old 12-04-2006, 04:02 PM   #3
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
The 670 is a 413. Just has a different bell housing. Internals are identical.
mwinkle353 is offline
Old 12-04-2006, 04:33 PM   #4
My Ride: 1993 dodge daytona
Induct: S/C
sorry to hijack the thread but i get so confused w/ these tranny numbers. if someone knows the numbers and descriptions would they mind making a list. may come in handy for those of us who dont know them that well.
m90daytona is offline
Old 12-04-2006, 05:32 PM   #5
Engine: 3.0L V6
6 cylinder:
A670 = 3 speed automatic
A604 = 4 speed electronic controlled automatic with overdrive
A543 = 5 speed manual shift
4 cylinder:
A404 = early 3 speed automatic transmission
A413 = 3 speed automatic (NA-lockup torque converter, turbo- non-lockup)
A520 = early 5 speed manual (4 plane shift pattern)
A525 = 5 speed transmission (4 plane shift pattern)
A523 = 5 speed transmission (3 plane shift pattern)
A568 = 5 speed transmission (3 plane shift pattern; R/T and VNT only)
Someone can chime in if I made any mistakes, or omitted any transaxles.
I'm sure I forgot about the 4 speed manual transmissions and one or two other automatics.
Old 12-04-2006, 07:09 PM   #6
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
670=lockup
looneytuner is offline
Old 12-04-2006, 08:30 PM   #7
Engine: 3.0L V6
Originally Posted by looneytuner
670=lockup
Yes, the 670 is a lockup.
But it can be modified for use without lockup.
Old 12-04-2006, 08:35 PM   #8
My Ride: '88 Shelby Z TII
A555: 4-cylinder 4-plane 5-speed TII only(from factory anyways) 4-pinion diff
The A568 could be has as a non-R/T tranny found in the few '90 turbo mini's that were made and the high torque TI's. Some were found with 2-pinion diffs in these applications.
It should aslo be noted that there are different input shaft sizes for the A523, A543, and A568. 1990 and some 1991 trannies got an input shaft size the same as the older 4-plane trannies. Later 1991-1993 trannies got a larger input shaft as well as gear sets with a more course pitch for higher load capabilites...
The A413 was later designated 31TH, as was the A670. Yes, the A670 has lock-up, but the designation started with the V6 application and was later grouped to any 3-speed hydraulically controlled tranny with lock-up. 31TH is the most current designation
The A604 is also known as the 41TE. It is similar to the A606(aka 42LE) and the 41AE(AWD version of the 41TE...don't think of using this for an AWD conversion...it WILL break).
There is also the manual found in the 16V Maserati TC's (A278??), but it can't be used in our application and is a Getrag unit. Just thought I'd trhow it in to the mix.
Reaper1 is offline
Old 12-05-2006, 02:11 AM   #9
Engine: 2500cc
ok so the A670 is as strong as the turbo's A413 so ill build it to my specs what i did for the turbo spirit the phantom grip 904X-treme will work hopefully and get a race clutch kit to rebuil it thanks for the help guy's but does anyone make custom converter's for the 670 trans?
Old 12-05-2006, 07:50 PM   #10
Induct: S/C
good info on this thread! thanks everyone.
Old 01-25-2007, 05:07 PM   #11
Do the neons with the A670 96 and up have 4 clutch drums? Do any of the A670's have 4 chutch drums? Anyway to tell? Any info appreciated. Pat
shelbyvnt2 is offline
Old 01-28-2007, 11:14 PM   #12
a670 strong i dont think it is in my 95 3.0L van my 2nd gear is almost gone
whE3Ls is offline
Direct TV | Loans | Loans | Car Loans | Car Finance
Page generated in 0.39753 seconds with 13 queries
