Old 12-15-2006, 08:03 AM   #31
My Ride: 1993 dodge daytona
Induct: S/C
Originally Posted by c2xejk
More likely they fear the humblizer....
more likely not... everyone on this forum said if they had a stock 3.0 and lived close to you they would do it.
m90daytona is offline
Old 12-15-2006, 08:07 AM   #32
why dont you recontact the guy who offered before Ed?
Im sure he wont be offended since I dont think he even plans on keeping the car.
Old 12-15-2006, 10:31 AM   #33
People "say" a lot of things.... The number of people that in this forum (3.0 Turbo) that have put there 3L on a real dyne is very small...
I have been toying with putting together a 3L V6 dyne day. Bring your wildest 3L see how it stacks up to everybody elses. Even thought about offering a cash prize to highest hp 3L...
If there is _REAL_ interest, I will put it together. Right now, I don't see many people that are interested in getting real numbers for what their car can do... Can't blame them, the dyne tends to humblize people...
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 12-15-2006, 11:14 AM   #34
Originally Posted by Ondonti
Would you like me to quote about 20 different times I have said "dohc" motor in various threads?
Do i really need to go and post dyno sheets again?
Do I need to post 3000gt threads that are called "dohc na overrated"???
My interest has been with the claim that the 12v 3l is "underrated"... So far I have yet to see hard proof, just a lot of speculative claims...
There were changes to the motors but I would say the 142 and the 150 are not actual exact numbers, but arbitrary ways of showing "improvement". The difference might be correct but that doesnt mean the actual number is.
Do you think adding .45 compression adds 10hp to a 140hp car BTW????Maybe 2hp. increased timing etc on the ODBII isnt going to get you there either because james Dempsey already showed that there isnt much to gain with timing advance. He only found 5hp..........and that was on a modified engine. Doubtful the odbII 3.0 computers even contribute to more hp.
You are talking two very different things. What Dempsey did was adjust the base spark. The computer controls the spark curve. I can very easily see changing the spark _curve_ resulting in more hp.
As I said, I have talked to a real spark calibration engineer. Any time _anything_ in the engine configuration is changed they redo their spark hook calibration maps... Where they set the production spark curve is depdent on many things including production tolerances. If they have shrunk the tolerances, they could likely push the curve closer to the theoretical best.
While I am on the subject, minor machining changes can make a big difference in engine performance... Talked to an engine calibrator who was working on the next model year of the GM 3.4L DOHC. The car was down on power and he wasn't sure why. As it happened I had a prior model year car that had been converted to the new electronics and cal set. He confirmed that my car performed as he would expect.
He was left with machining changes... Ultimately it didn't matter, because the DOHC engine was axed for that model year. (High warrenty costs and a better option)
As for OBD2, that is just a set of diagnostics. A very LARGE set of diagnostics, but by itself it doesn't buy you any peformance gains. Spent a year working on/with some of the OBD2 code for '96 model year vehicles.
Some of the learning algorithm data might be helpful for tweaking some of the calibrations on the fly.
The larger processor made more complex/accurate fueling algorithms possible... So you could have some minor gains there. Increased accuracy of the spark timing would also be possible. You could have had a stack up gains that neted a few hp.
The 224hp dohc 2.2 chrysler will dyno 35-45whp more then a 220hp mitsu dohc v6 when both are stock........Here you have chrysler underating a motor. It doesnt even make sense in this case.........If they were rating HP like mitsu does for its 24v motors then the 2.2 dohc chrysler would be rated as making 275hp.
I had a T3, factory hp was about right. But the engine was exhaust choked... Open the exhaust and instant power upgrade at every RPM...
Edward Kelly
c2xejk is offline
Old 12-15-2006, 04:13 PM   #35
You might want to do your 3.0 history work a little better.
james dempsey was adjusting the spark curve not the base spark.............He spend 500 bucks to be able to do that.
Old 12-15-2006, 06:11 PM   #36
Induct: S/C
what was done to that van you dyno'd? auto or manual? it made 146 at the wheels w/ the stock tb.
Old 12-15-2006, 07:35 PM   #37
Actually I didn't do any searching. So he made 5 hp more than ???. More than just adjusting the base timing? Considering my van picked up ~4whp over stock timing by adjusting the base timing. 9whp over stock would be a rather significant gain... 5 hp over stock timing would not be much of a gain.
Edward Kelly
c2xejk is offline
Old 12-15-2006, 07:46 PM   #38
I don't have the dyno charts on this computer to verify the exact number. I can tell you the run you were referencing had a stock plenum and TB.
The van still had the ported lower intake, ported heads, stock exhaust manifolds, 2.5" exhaust w/2 mufflers and no cat, open filter. The van has a 5-sp out of a '92 or '93 Shadow. I am sure I am forgeting something, but the mods in the other thread.
If it were AT, you would have seen a bigger spike in the torque curve at low RPM...
Edward Kelly
c2xejk is offline
Old 12-15-2006, 07:46 PM   #39
Induct: S/C
so you think that you got 40+whp out of those mods? assuming 24 percent hp loss through drivetrain (because thats what the eclipse supposedly had) would put the van at 107whp stock. you got 146 at the wheels which means at 24 percent drivetrain loss, you made 181 at the crank. which means you added 40hp using the STOCK tb...and w/ the big tb it puts you at 193 crank hp.
my point is either the eclipse is over rated or the 12v is under rated...maybe both.
Old 12-15-2006, 08:57 PM   #40
I never claimed any such thing. PERIOD.
I have never used any number for drivetrain losses other than 15% for a manual. PERIOD.
Let me start with, the eclipse is one data point for the 24v SOHC engine... That is what it did on that particular dyne on that particular day... Maybe there should be more correction because of atmospheric conditions, I don't know.
Maybe I should scale my numbers up, I havn't. The numbers are the numbers...
Edward Kelly
c2xejk is offline
Old 12-16-2006, 01:15 AM   #41
He gained 5hp after everything else he had done.
500 bucks for 5 hp didnt make him happy
Old 12-16-2006, 01:20 AM   #42
the base v6 eclipse is only rated at 205 crank hp....then the GTS is rated at 215..maybe slightly overrated......
but the dohc motor is supposedly 220hp and it makes the same or less hp on the rollers then the base v6 eclipse.
I dont know if mikes Eclipse was a base v6 or a gts. If it was a GTS then its supposed to make 215crankhp.
Old 12-16-2006, 07:50 AM   #43
He probably saw the claims of some the aftermarket reprograming tools that talk about big gains from reprogramming spark... Those claims are at best over hyped. They are likely going from the worst possible setup (ie worst case factory tolerance stack up) to the best.
From what you are saying, he likely had already tweaked base spark advance, so an additional 5hp (whp?) is actually pretty good.
It's funny, I know some pro's that would parts of there anatomy for even 3 honest hp.... Once you reach certain levels, more performance is tough to come by... I have spent hours on the flow bench looking for and trying to understand small gains in flow. And I know I will be spending even more hours pursueing even smaller gains... Time is money...
The big gains in flow tend to come early. They are the low hanging fruit. Smaller gains come later and are much tougher to get... Dempsey was going after the smaller gains and he now has a tuning tool for when he makes other changes.
But back to your comments, it sounds like the factory could push hp up by 9whp just by changing there spark curve...
Edward Kelly
c2xejk is offline
Old 12-16-2006, 07:57 AM   #44
To me the truely interesting part is that despite putting down higher numbers on the dyne, my van was quicker on the street... Same dyne, same day so his car legitmately puts down more hp than my van. However, on the road, my van can walk away...
Edward Kelly
c2xejk is offline
Old 12-16-2006, 08:28 AM   #45
Induct: S/C
so what all was done to the heads on the van? did you flow bench them? what where the results?
