12-27-2006, 06:18 PM
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
It wasn't you that got me upset. It's the fact that you didn't state that you were going forced induction and someone had stated that 27# injectors would be too small.
And by "impedence", it's the resistance of the injector. If you take a low impedence injector, you'll most likely see 2-5 ohms of resistance. A high impedence injector will be between 10-16 ohms of resistance. Take, for example, a honda turbo upgrade. They will install DSM injectors, because they're larger. But they have to install resister blocks as well. So, they don't burn up the ecu's injector drivers. But, they (honda owners) have a way to alter the programming of the ecu to compensate for the larger injectors. Where as we do not.
I should have put a smily at the ending statement. I guess my humor is too dry for internet traffic.
But, in all honesty, I don't see any reason to install larger injectors on the car, if you don't plan on adding boost or nitrous. Just get an adjustable fuel pressure regulator, if you need just a little bit more fuel for the modifications you're running.
And just for the record. I was running exactly the before mentioned modifications on a completely stock fuel system without any issues. However, I gained an estimated 5hp when I installed my adjustable fuel regulator.
