Old 01-01-2007, 11:19 PM   #16
what compression ratio do you have? btw what do your compression tests say (just wondering)
Old 01-02-2007, 07:25 AM   #17
How did you check the vacuum? I assume you have an A/F gauge telling that it's rich at idle? You might want to try swapping the MAP sensor out, see if that makes any difference. Could be running rich all the time, but you only notice it at idle, because it's not running fast or getting as much air.
Force Fed Mopar is offline
Old 01-02-2007, 09:49 AM   #18
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
already swapped MAPs. I know it's rich because it smells PIG rich. Used a gauge and when the engine was running hooked it up to a vac source and it held a steady 20-22inches.
Brent, CR is stock. Heads have been milled .024.
DustyR/T is offline
Old 01-02-2007, 03:37 PM   #19
Oh this is just your stocker motor :P
Old 01-03-2007, 06:02 AM   #20
yea Brent, my built motor hasn't been installed yet and won't until my turbo setup is complete w/ my standalone.
I did go ahead and swapped for a new coolant sensor last night. Haven't started/ran it yet since. I'll report my findings
DustyR/T is offline
Old 01-04-2007, 10:29 AM   #21
I swapped the coolant sensor. Little to no difference. Though I did fix my stalling problem by swapping pick-ups and TPS's.
I'm still blaming the rich idle/mid-range on cams. It's ok. Perhaps they'll work to my advantage w/ the turbo. =)
DustyR/T is offline
Old 01-04-2007, 08:40 PM   #22
Do you have an A/F meter?
I wonder if a little drop in base pressure wouldn't help some.
Ntrain2k is offline
Old 01-04-2007, 10:51 PM   #23
did that. More than a little. 38psi. Runs a little better like that actually.
No A/F meter.
DustyR/T is offline
Old 01-04-2007, 11:35 PM   #24
My Ride: 1993 dodge daytona
Induct: S/C
maybe want to pick yourself up a wideband if you gonna do a turbo eventually anyway. i recommend the innovative motorsports. its one of the cheapest but also one of the best in my opinion.
m90daytona is offline
Old 01-04-2007, 11:36 PM   #25
but what is that going to do from 5000-6000 rpms
Old 01-05-2007, 12:01 AM   #26
Induct: S/C
what is what going to do?????????
Old 01-05-2007, 06:37 PM   #27
think Brent is referring to my fuel pressure. It feels alright. It could be better in that range. Mid range seems to be my best right now.
DustyR/T is offline
Credit Card Consolidation | Mobile Phone | The eBay Song | Free Verizon Ringtones | Xbox Mod Chip
Page generated in 0.36474 seconds with 13 queries
