Old 11-26-2007, 05:21 PM   #331
Re: Who wants a custom ECM calibration?
My Ride: 95 Caravan SE
brrrrrrrrrrrrrrrreakthrouuuuuuuuuuuuuuuuuuuuuuuugh ?
lookin is offline
Old 11-26-2007, 07:06 PM   #332
My Ride: '90 Voyager
Engine: 2.5 16V Twin Mitsus
A "Romulator" is a piece of hardware that plugs into the EPROM socket on your computer and allows you to make changes "on-the-fly" since it uses a different memory technology that is faster, but requires a controller and connection to a computer.
We've figured out the flashable SBEC, but there are a couple problems yet. Biggest one being that it doesn't program properly using D-Cal. The main problem with the slowness of flashing is that the HC11 doesn't support any standard data rates above 9600bps with the speed that it runs at in these computers. It is possible that using a USB -> serial adapter that supports non-standard baud rates and with some mods to D-Cal that the flash speed could be much faster. But that's after we actually get it to take a cal...
90TurboVan is offline
Old 11-27-2007, 07:01 AM   #333
My Ride: Titan & '89 C/S AGS
Engine: 2.5L T1
What do you think the problem with D-Cal is? Is it actually in the flash? Or in the verify? The current released version of D-Cal doesn't verify 32k bins correctly. It doesn't know to skip the EEPROM section (B600-B800). Derek made me an updated D-Cal release that fixes that. But, I don't think he released it publicly.
I had asked him about supporting the USB cable, he didn't seem too keen on it. I guess it would take a big re-write of his comunications code.
I guess this part of the discussion really belongs on the MoparChem or D-Cal forum. Sorry for the off-topic, guys.
Shel-Game is offline
Old 11-27-2007, 07:17 PM   #334
It's all fascinating as heck to me really.
lookin is offline
Old 11-27-2007, 07:52 PM   #335
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
Assuming for the moment that the current problems with getting the 92+ SBEC code unlocked and decoded continue, I think I have an alternative suggestion.
Megasquirt - Here's what to do.
Megasquirt becomes the standard engine controller for modified 3.0's. So you just get one and put it in, plain and simple.
Now what about programming and tuning Megasquirt?
Here's the part I think will work out best.
Someone will make a good calibration for a couple engine types. Just like how Turbo 4 cylinder calibrations are being made right now. Like one with light mods and N/A, one with more mods and N/A, and one or more versions for Turbo 3.0 cars.
So if you have a mildly modded 3.0 with certain things, like a ported intake, 52mm, stock injectors, K&N, 2-1/2" exhaust, stock cams, and mildly ported heads, a calibration would be available that would at least get you pretty close to having a smoothly running engine. Then it could be run as is or the end user could fine tune it a bit more.
Just putting this suggestion out there.
Tim_K is offline
Old 12-06-2007, 04:40 PM   #336
My Ride: 94 shadow es
Originally Posted by Cromax View Post
Sounds like theres a preety solid demand, theres been over 20 of us that said wed put the money down.. and theres teenagers all the time who get a Shadow or Spirit as there first car who will start in the 3.0 modding craze also
i am one of them
94ShadowEsAuto is offline
Old 12-06-2007, 04:42 PM   #337
Originally Posted by Chris W View Post
I agree with you that it is alot of work to create a custom cal for these vehicles. The problem we see as a vendor is that once we invest our R&D time and $ to get the numbers, someone else (vendor or individual) will just come along and copy our work. Their "break even point" will be far less then ours so they can offer the cals at a discount which makes it difficult for us to recoup our investment or actually create revenue. These are the challenges we face in a niche market. If there was a way to guarantee a return on our investment by either money up front or a non-compete agreement between vendors/individuals you would see a whole lot more products coming to this market from us. Based on history I don't see that happening.
Chris-TU
im pretty sure id still stick with TU even if some other vendor made it cheaper.......i know what im getting for the money with you guys
Old 12-06-2007, 11:05 PM   #338
Same here. TU rocks.
lookin is offline
Old 12-06-2007, 11:44 PM   #339
92lebaronGTC's Avatar
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
Images: 30
I would only buy one through a supporter of the community like TU.
-Steve Reject.
92lebaronGTC is offline
Old 12-07-2007, 11:05 AM   #340
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
The only way it will happen is if someone in the Detroit area can go see chris. Id go but with work and the christmas season im just a too far south to make a road trip. Maybe if we still dont have one by next summer i could.
irocelectric93 is offline
Old 12-07-2007, 12:27 PM   #341
There are 3.0's in the detroit area......they are just owned by TD people not 3.0ers so they dont care.
Old 12-07-2007, 12:55 PM   #342
Engine: 3.0 V6
Images: 2
Good point brent.
Old 12-16-2007, 10:08 PM   #343
My Ride: 2.5 Dodge Dakota
Does any one have any fuel / spark maps for 2.5L DODGE motors? Anyone out there reverse-engineer the factory cals? Megasquirt cals?? $$$$
tominator2.5 is offline
Old 12-19-2007, 10:52 AM   #344
Engine: 2.5L T1
Well, yeah. Go check out ... oh, never mind, the links would be blocked anyway. Suffice it to say, there are other web sites out there with a ton of info on the stock and modified factory turbo cals from '87 thru '91...
Old 12-19-2007, 11:04 AM   #345
Engine: 3.0 V6
What's the big secret? I don't know the exact links, but these people are probably referring to something at turbo dash mopar dot com.
Big F'in deal on what site the information is on, that's how I see it.
Tim_K is offline
