Old 02-13-2007, 04:11 PM   #31
My Ride: 93 Sundance Duster
Engine: 3.0L V-6
Originally Posted by 86Tona
Then where did he dig into the manual to pull up the 'sample'. There isn't a 'dip stick' on a manual tranny.
He probably pulled the fill plug while in the pit. I do that at my job. I get a sample from every manual tranny that comes through.
93sundance is offline
Old 02-13-2007, 04:16 PM   #32
Engine: 3.0L V-6
Originally Posted by Eight-Sixer
I used to work at a Jiffy Lube (used to, but thats another story for another time) and the lower bay "techs" could not do a damn thing right, this one "tech" double gasketed an oil filter, the customer drove off, was halfway home when her engine seized up,
K.
At my job we are required to call out "no double gasket by sight or feel" while installing the oil filter. Then we have to check the filter for leaks when the vehicle is started, and call out "ok bottom side". Overall, I like the way the business is run. We make damn sure everything is done right before the customer leaves.
Old 02-13-2007, 07:51 PM   #33
I used to work at a Jiffy Lube (used to, but thats another story for another time) and the lower bay "techs" could not do a damn thing right, this one "tech" double gasketed an oil filter, the customer drove off, was halfway home when her engine seized up.
Doh! I did that on my car once. Started it up and oil went EVERYWHERE. I've never seen that much oil shoot out of a car that quickly. The car only ran for 30s while I moved it, but it pretty much blew all of the oil all over my driveway. What a mess! To this day I don't know if the old gasket stuck to the mounting block or if the new filter had 2 gaskets on it. Either way, you can bet I'll check that next time.
mightymulhern is offline
Old 02-13-2007, 08:18 PM   #34
92lebaronGTC's Avatar
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
Images: 30
In my shop class, we attempted starting this 74 jeep but didn't notice someone took the oil filter until I see black sludge hitting the floor like a hose! I immediately yell at my friend to kill it. Oil flows pretty quick even when first turning the key. Always double checked from then on!
-Steve Reject.
92lebaronGTC is offline
Old 02-15-2007, 12:01 AM   #35
Engine: 3.0L V-6
I'd say on average, about 1 out of every 50 oil changes the gasket sticks to the block. At my job, it happens once every few days. On average, I probably service about 25 cars a day.
Old 02-15-2007, 11:45 AM   #36
Location: a box under the stairs in the corner of the basement of the house half a block down the street from jerry's bait shop...you know the place!
My girlfriend uses the old standby..."my boyfriend said you'll change just the oil, and you'll do just that because he'll check it out when he gets home." I'm glad that she trusts me more than them because they can see it in her face. Nobody has ever tried to convince her after that!!
And for the record, I was working 80 hours a week the last time she took something in. Now, I live in a rented house, nice neighborhood, and I'm afraid of making a huge mess. The driveway at my house in Florida took me 4 hours with a pressure washer and 5 gallons of chemicals to clean. oops.
macncheese is offline
Old 02-18-2007, 01:05 PM   #37
My Ride: 1993 Dodge Daytona
Engine: 3.0 181
ill tell you guys a good on e my dad has a 94 baron gtc 3.0/a604 and i was just under it 2 weeks prior replacing the front motor mount and the cv axles were fine so anyway my dad goes into monroe for their "$11.99 special oil change" what a joke they call him outside because "they found a problem with his cv axle" he goes out there to find a clean razorblade cut all the way around the cv boot with no grease flung anywhere like it just magically stays inside the axle when its spinning at 2,000+ rpms ok buddy my dad threatened to sue them and they gave him a new cv axle free of charge and labor. this type of thing happens all the time with commission demanding shops some places if the employees dont sell a certain amount they start gettin 50 cent deductions in pay untill they do
TimTona is offline
Old 02-18-2007, 01:34 PM   #38
black86glhs's Avatar
My Ride: 1986 GLHS
Engine: 2.2 turbo
Thats why I'm on welfare...no crap to deal with...LOL!!
Just kidding...I'de make more money if I were...damn place I work is so cheap.
black86glhs is offline
Old 03-01-2007, 02:53 PM   #39
My Ride: 1990 Daytona ES
Engine: 3.0L V6
I never go to oil shops, i installed a fram quick change fitting on my engine, works great, and don't worry about cross threading a pan.
On the other hand i don't have any welding tools, and my exhaust broke before the muffler (just before 1.75" reducer), they charged me 45.00 for the repair, i paid it and in less than a couple weeks it started to get louder in after the 3rd week it broke apart again. I call the shop and they say they don't guarantee patches when i specifically asked the guys there when i got it done saying it was guaranteed. So i get a patch kit for 8$ from advanced and found only a couple of spot welds on the pipe where it broke I paid all that money for a half-assed job! Now with the patch its working ok, i didn't do a great job so it isn't 100% sealed up, but will be getting a new catback exhaust before my next e-check so i'm not worried.
roguetrip is offline
Old 03-04-2007, 09:51 AM   #40
When I initially posted this rant, I didn't expect it to get nearly this much feedback. I guess it's nice to know that everyone else is as equally bitter on the topic, but it's really sad that the only one you can trust to touch your car is you. Oh well.
Old 03-04-2007, 10:19 AM   #41
My Ride: 1986 GLHS
Engine: 2.2 turbo
Similar story but about brakes this time. As a previous shop owner, I understand the need to make $$$$. However, $600 for rotors, pads and calipers???!!!
My wife's cousin goes to Firestone to have the brakes looked at. It is a 94 Buick Park Avenue. Well, I go to NAPA and get pads and rotors for $85. I pull out the caliper pins and rubber inserts, hone the caliper slide holes and grease everything. Put it all together and it works great(I've done this so many times, I've lost count).
I know roughly how much the parts cost Firestone. They get loaded calipers and rotors for about $85-$105 total cost. I would have been a rich bas*@rd if I had made money like that! LOL!
Old 03-06-2007, 10:01 AM   #42
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
This was many years ago--when I was like 12 or so...
Dad brought our Plymouth minivan in to get an oil change, tire rotation, basic inspection blah blah blah since he didn't have time to do it.
One Sunday morning, I was still in bed, barely awake and a hear the sound of him prying off a hubcap out in the driveway. Then there was silence, and then the sound of the wrecking bar (his prying tool) slamming against the ground and a LOT of mad swearing going on. I knew the plan was to kill someone very soon.
Dad always liked to kinda double-check other peoples' work, and thankfully he did. The dealership installed all the lug nuts finger tight and BACKWARDS. BACKWARDS! All five lugs on all four wheels could be taken off with your fingers. This is proof of how long you can really drive with loose lugs before they come off. Dad was about to put them on right and mom stopped him and said, it lasted this long, there is no way it won't last another 8 miles to the dealership for them to see themselves.
The next day, mom drove it over there, pulled right into the shop to block service department traffic and bitched.
It wasn't long after that they fired their entire service department (re-hired some) and got all new people there.
We drove the crap out of that van during this time and even hauled around a really heavy cast iron bathtub in the back end for many of the miles because we couldn't get it out after the forklift set it into the van originally.
phantomrt is offline
Loans | Personal Loans | Car Accident Attorney Los Angeles | Car Insurance | Loans
Page generated in 0.43571 seconds with 13 queries
