Thanks RoadWarrior222 for posting the info. That was darn nice of you.
The whole subject of oil is very complex, and I can't sort fact from opinion. I believe you are right about mixing oils and switching types though. I just don't understand all this stuff is all I am saying. There does though seem to be some truth to the controversy regarding Mobil1 now being group III hydro-processed semi-syn, and because of this I am switching to Mobil1 EP, as that may be their better formula now.
Last year I did one oc with redline 5W 30. I thought maybe their ester formula, would clean the insides real good, and act to counteract the reported ill effect PAO has on engine seals. That
was expensive, and a lot of it went right through my PCV valve and into the intake on a road trip. So I didn't leave the Redline in as long as I intended too. I did an oc with Mobil1 again a little earlier than I had intended.
Also, a couple of months ago, I did an oc with Valvoline 10W 40 dino. I ran it hard for a few hours on some back roads, and then I went through all the gears several times, letting off to flex the rings. Then I then drained it hot.
The dino came out absolutely black! I was amazed, all that crud was still in there, even after 5 years of running Mobil1. Apparently, M1's additive pack and cleaners, do not deal 100% effectively with old dino deposits.
The whole idea was to use Valvoline's dino detergents, which
are designed to handle dino deposits, to get out any remaining crud left over from the first 46,000 of miles of dealer service.
I then refilled with Valvoline 10W 40 again, and I ran it for a month of normal dd. Then I drained it hot again. It came out black for a few seconds, then less so, and then it became medium amber. I then refilled with Mobil1. New NAPA Silver filters each time btw.
Doing that
did improve ring seal apparently, which was the idea, because manifold vac went from 18"Hg at 1000 RPMs in neutral, to 20"Hg at 1000 RPMs in neutral, over the next few weeks on the M1 refill.
Monday I am draining it hot again and refilling with Mobil 1, extended performance this time, and a new Purolator PremiumPlus filter is going on. I am still not sure how I feel about extended oc intervals, and I doubt I will let it go over 5,000 miles or 5 months.
I did the procedure, I just outlined, at the advice of very knowledgeable friend. I was was very hesitant to do it, but he really does know his stuff, and I am very glad I took his advice.
Regarding the redesigned valve cover thing.
The dealer parts guys say, there is only one valve cover part number listed, for all 3.0s of all years. I still don't know what to think.
I do really like the parts department at the Dodge dealership I go to though. They are great guys, very patient with my stupid Qs, and they don't charge me an arm and leg for mopar parts.
Please excuse me for making this such a long post. Hope it doesn't bore anybody to death.
