03-13-2007, 07:47 AM
#16
My Ride: 95 Caravan SE
Originally Posted by m90daytona
i think it depends on what car the 1995 is
and
yes it is okay to install on a stock 3.0. although if you plan on leaving it stock i would go w/ the 185 lp/h.
OK. Thanks for the reply.
It's a 1995 Caravan SE. Cowl inducted air, command-flo fprm, p&p'd plenum, 52mm tb, udp, 2.5" exhaust with hi-flo cat and magnaflow straight shot, and I may, very likely, add a turbo for -5lbs boost some time before next fall.
Maybe a better question would be. Will I even need, larger than stock injectors and a bigger pump, if I plan to stay with just a couple pounds of boost? I don't expect an answer to that here though.
Thanks to 3.0l Sleeper also for the reply.
