Old 03-13-2007, 07:47 AM   #16
My Ride: 95 Caravan SE
Originally Posted by m90daytona
i think it depends on what car the 1995 is
and
yes it is okay to install on a stock 3.0. although if you plan on leaving it stock i would go w/ the 185 lp/h.
OK. Thanks for the reply.
It's a 1995 Caravan SE. Cowl inducted air, command-flo fprm, p&p'd plenum, 52mm tb, udp, 2.5" exhaust with hi-flo cat and magnaflow straight shot, and I may, very likely, add a turbo for -5lbs boost some time before next fall.
Maybe a better question would be. Will I even need, larger than stock injectors and a bigger pump, if I plan to stay with just a couple pounds of boost? I don't expect an answer to that here though.
Thanks to 3.0l Sleeper also for the reply.
lookin is offline
Old 03-13-2007, 08:21 AM   #17
My Ride: 1993 dodge daytona
Induct: S/C
yes you will at least need larger injectors and i would do the pump too.
m90daytona is offline
Old 03-13-2007, 09:27 AM   #18
Even for a measly 2lbs? OK. Thanks m90daytona.
lookin is offline
Old 03-13-2007, 12:45 PM   #19
My Ride: Shadow ES
Engine: 3.0L V6 12v
ok so i just bought the pump.. but i have a question... how hard is it to install.. i thought the sending unit was a different peice.. but when i called to get a price they told me that the fuel pump and sending unit are one peice.. looking at the picture of the pump i bought (walbro 255lph) it looks like i need something else.. im going to buy a new fuel tank, lock ring, tank straps, and the 255lph pump... what else do i need to make it a new setup?
3.0l Sleeper is offline
Old 03-13-2007, 01:30 PM   #20
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
Why just go with 2lbs? If your going to do it at least run 5. It would be more worth your while anyway. If you go with -5 it wont really be worth your time...setup and everything and this is assuming youll spool decently.
irocelectric93 is offline
Old 03-13-2007, 03:44 PM   #21
Induct: S/C
i got my sending unit from advance auto parts. it came w/ the stock pump inside. i removed the old pump and put the new one in. there was a little bit of fabrication involved but it wasnt hard.
also, running 2lbs of boost isnt really worth running any. you may see 15-30 hp at best but if you really want to make an extra 30 hp i would reccomend heads and/or cams.
Old 03-13-2007, 06:01 PM   #22
3.0l Sleeper sorry I hijacked. I'll wait to ask my boost questions later.
Thanks everyone.
p&pd heads & cams .... hmmmm
lookin is offline
Old 03-15-2007, 12:25 AM   #23
My Ride: Shadow ES
Engine: 3.0L V6 12v
ok well then i guess im gunna have to buy the sending unit with the stocker pump in it and just sell the stock pump...
Personal Loans | Mortgages | Article submission | Credit Counseling | Mobile Phones
Page generated in 0.77734 seconds with 13 queries
