03-18-2007, 12:51 AM
#20
Yes the numbers on that site are correct, the numbers your posted for the 3.77 trans for example, are wrong.
The MPH math is also wrong for a 195/60r15 tire your numbers are very low.....its like you are using a 22" diameter tire.
Here is a543 gears from the site you posted. Notice how your info is all wrong?
You are doing something wrong when calculating MPH too.
I think you are basing your need for a certain gearing in your trans off of incorrect information. Also using those tiny tires as reference doesnt help either. Wont matter what gears you have if your tires are that small, especially with a supercharter.
My duster has 195/60r15 azieniz or whatever they are from the previous owner and they are useless for traction. i will probably swap tires with the spirit unless I just get something more useful for the street.
Gear Ratio
(1990-1991) Ratio
(1992-1993)
1st 3.29:1 3.31:1
2nd 2.08:1 2.06:1
3rd 1.45:1 1.36:1
4th 1.04:1 0.97:1
5th 0.72:1 0.71:1
Reverse 3.14:1 3.14:1
Final Drive 3.50:1, 3.85:1 3.77:1
Overall 2.52:1, 2.77:1 2.68:1
