04-30-2007, 12:51 PM
#18
My Ride: '88 Plymouth Voyager
Engine: 3.0 V6
My guess is that it didn't actually drop gear, but aquaplaned on one side, the revs went straight to redline (giving the impression of a downshift) with the diff giving 100% to the spinning wheel, then all of a sudden it found grip again and flung the back tires around on the water that aquaplaned the front. Wider tires can aquaplane on less water depth than stock tires, especially if they are unsiped "summer" tires and not all season radials.
Tips for all those who'd like to avoid such situations, develop a feel for steering feedback, (goes real loose) and seat of pants feel (kind of a shiver/shimmy) so you know the instant you're aquaplaning. Then lift off the gas slow and keep the steering straight, even if you seem to be headed towards the guardrail. Sometimes you can lightly coax it back, but don't over-react. It woud be better to just grind the side on the guardrail than to punt it with one end or other of the car, and have it bounce you into traffic. Often though, you'll feel the grip come back in time to avoid anything, it doesn't usually last long unless you power into it, or panic and hit the brakes or throw the wheel over hard. If you find yourself needing to make a drastic manoeuvre, like your lane just came to a standstill ahead and you're aquaplaning towards it, if you've got room still, cadence brake, which can break through the water film, though be real careful to do it in a straight line and get ready to catch the back end. (This is one sitch where ABS sucks unless you've got lottttttts of room, coz it won't set up the pitching that might break the plane, it just keeps letting the wheels roll, it's fine if you've just got a wet road with a puddle or two, but if you've got like a sheet of water over the road, it can screw you up) If you really, really need to try to swerve, which is highly inadvisable, 8 times out of 10 you'll just spin, give it a quick flick, in the direction you need to go, very small steering movement, 1/8 of a turn or less at speed, then flick it back the other way immediately, if you wait until you feel the back end begin to come too far round, it's usually too late and you'll have to wait until you've gone right round and hope you've got the grip to flick it out when you're about 7/8 of the right way round again. Best plan of all though, go to a skidpan where they have instructors and get a lesson or two. Get some friends together, make an event of it, will probably work out cheaper in a group.
