Old 05-02-2007, 07:14 AM   #1
replacing transmission needing help
im am replacing my transmission and i have a linkage form my throttle body to my transmission how do u lose that and want transmission should i get
note: 95 3litre van ty
whE3Ls is offline
Old 05-02-2007, 08:44 AM   #2
My Ride: 94 dodge caravan
Engine: 3.0L V6
That your kick down linkage. There is a little clip that holds it to the throttle body.
baja73 is offline
Old 05-02-2007, 05:37 PM   #3
i pooped it off once and had no power
whE3Ls is offline
Old 05-02-2007, 06:08 PM   #4
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
You will burn the clutches out of your new transmission without the kickdown linkage hooked up and properly adjusted.
If you don't know what you are doing, (and it sounds like you don't know JACK about transmissions ), pay a tranny shop to do it or find someone who has at least half a clue as to what they are doing.
Tim_K is offline
Old 05-02-2007, 07:09 PM   #5
My Ride: 2 messed up dodges
Engine: 10:1 3.0 5 speed
Images: 1
yeah you need the linkage that goes to the throttle body connected. Get an a670 since that is what you have now.
jory is offline
Old 05-02-2007, 07:35 PM   #6
that was on my transmission im replacing
whE3Ls is offline
Adsense Tips | Xbox Mod Chip | Loans | Debt Consolidation | Problem Mortgage
Page generated in 0.29765 seconds with 13 queries
