Old 05-05-2007, 07:04 PM   #1
traction
what are you guts running for tires on your 3.0 i have 225's with the turbo nation lsd, and even at 20 kph or faster and jump on it breakes completly loose, and there's no way to launch it with out a smoke show,
mopar3.0 is offline
Old 05-05-2007, 07:52 PM   #2
My Ride: 2 messed up dodges
Engine: 10:1 3.0 5 speed
Images: 1
i have 205's all around. no problems with traction as long as I dont launch too hard. just take it easy in the first 2 gears so you dont blow the tires away. like find the perfect throttle where you wount blow the tires away but still get moving.
jory is offline
Old 05-05-2007, 07:53 PM   #3
My Ride: 93 Sundance Duster
Engine: 3.0L V-6
I ran 225/50/15s on my high compression duster, with an open differential and I did 2.03 60 fts. The 1/4 mile was 14.2s @ 96s
93sundance is offline
Old 05-05-2007, 07:56 PM   #4
i have falken zeix ze 512 stock diff they only break loose when its wet
225 45 17
whE3Ls is offline
Old 05-05-2007, 09:22 PM   #5
Move to high elevation and your problems will go away lol.
Old 05-05-2007, 10:42 PM   #6
Engine: 3.0L V-6
225 45 17
Those tires worked good for me I had 225/50/15s and I cut 2.0-2.1 60 fts all day. I ran a 14.3 @ 94 w/ 2.03 60 ft with those tires. Damn good for cheapo all seasons.
Old 05-06-2007, 10:04 AM   #7
i wishi never toasted my high compression motor,
i bet the car would still run 14's with traction if can can every get any, lol
i woudner how big of a slick i could fit,
and i dont even have my msd box on yet, always made hugh diffrence on my 3.0's
i aslo have 3 85 final drive
mopar3.0 is offline
Old 05-06-2007, 10:18 AM   #8
My Ride: '88 Plymouth Voyager
Engine: 3.0 V6
Awesome news on those Falkens, that's just what I was looking for. I was considering the Kumho ECSTA - ASX (or something like that) too. Putting them on 15 inch pumpers on the van, so need a slightly taller tires, so will need 225/60/15s, so hope those are as sticky as the 50 profile.
RoadWarrior222 is offline
Old 05-06-2007, 01:03 PM   #9
My Ride: 93 LeBaron sedan
i have 3.85 fd also and thanks to brent i now run 225 60 15s and u just hafta find the sweet spot, i will still spin the crap outta the tires if i rev too high.
Boogieman142 is offline
Old 05-06-2007, 02:11 PM   #10
Engine: 3.0L V-6
My car hooked up real well with the 10:1 motor. I had to feather the gas though.
Old 05-06-2007, 03:10 PM   #11
yea i had timming problems with my msd timming controller which led to shitty bottom end power, but sick up top and by the time i figured out that my msd was the problem it was too late, driving home started to knock, pulled the base pan and was full of shavings,(still had full oil pressure). skirts were broke off a couple of pistons,
mopar3.0 is offline
Old 05-06-2007, 05:29 PM   #12
I like those size tires because they fill up the wheel well.
Ive never sprung for good traction tires though.
I think the tiny 195/55r15 Falken Ziex Ze (front only, they are very old and came with the car) on my duster grip a lot better then my kumho HP4 225/60r15.
In the future I might buy "better" tires for at least the front. My tires seem to wear very evenly so Im not worried about rotating them.
Old 05-06-2007, 06:24 PM   #13
thinkng i might get a set of small wheel spacers and go with 235/50/15 mt street e/t
mopar3.0 is offline
Old 05-06-2007, 07:10 PM   #14
Engine: 3.0 V6
I'm figuring on cutting down a couple of old rotors for spacers if the 225s need it. Word is the studs are only long enough for about 1/4 inch of spacer, nuts only go half on with as much as 1/2 inch.
Old 05-06-2007, 07:37 PM   #15
My Ride: 95 Caravan SE
I run 195/60/15, V rated, Kumho ECSTA ASX tires. Since they are all season tires, they are neither too hard nor too soft, and they grip really well wet or dry even in cold weather. They are really holding up too, unlike the last set of Kumhos I had, and I couldn't be happier with them.
Here is a link about them. Kumho ECSTA ASX
lookin is offline
MPAA | Vegas Hotel | Mortgage Calculator | Mortgages | Personal Loans
