06-27-2007, 07:26 AM
#51
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
I took my motor apart yesterday (still in the car). I meant ti take some pics but I forgot. Anyway, I found the motor has .25mm bearings in it so someone has been in the motor before me. I didn't bother pulling the rod bearing caps but the main bearing looked terrible. The main bearings were all worn down to the copper and bearings and crank journals were scored pretty bad. Looks like I'll be buying a junk yard motor and rebuilding it with forged pistons instead. Oh well, I installed my new oil pump anyways and so far I have much better oil pressure but it still isn't what it should be. I have 15psi at idle and 30 psi by 2000 rpm with fresh 10W30 oil.
