06-13-2007, 07:35 PM
pic of my spirit
 after spending well over 5 grand on and blowing up my 10.1 motor i sold it but i missed it too much and bought it back , now has a stock compression motor with all my bolt ons, i willing to bet the car will runs high 14's when its running right,
Mods done as of now
shelby sway bar
strut tower brace
magnaflow muffler and dynomax axel back
160 degree thermo stat
msd 6a ingntion system
msd susper stock coil
accel wires
true cold air intake
dodge neon short shifter
Booger bushings
58mm thorutle body 5 speed a543 with 91 323 internals with 3.85 final drive
bores peformance under drive pulley
icon 15 inch light weight wheels
kumo 225/50/15 rubber
ported heads
58mm throuttle body
lightweight sterring wheel
t3/t2 clucth set
t-trac drop in lsd
read disc break conversion
bigger break master cylinder
steel braided break lines
lomandi pads and front crossdriller/slotted rotors
camber kit
06-13-2007, 08:05 PM
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
Did ya take a beating on the price when it was sold/sold back to ya?
06-13-2007, 10:36 PM
My Ride: 89 Shadow
Engine: 2.5 turbo
why did you put a t2 t3 combo in it. the 3.0 plate is the same as the t3 plate and the disk is as well.
160 t stat is to cold. tried on on my old 3.0 car ran to rich and didnt have any power increases
but nice car though
06-14-2007, 01:16 PM
My Ride: 1990 Daytona
Engine: 3.0L V6
but nice car though
Its easier to get the t2/t3 combo from fwdperformance. its still a sachs unit though.
And i agree about the 160*, too low, atleast run a 180*.
Even with all your mods, unless you pull alot of weight w/10:1+overbore, you'r more than likely looking at mid/high 15's.
And isn't that T-trac LSD like phantom grips LSD, if so then its crap for the track or any real drag. OBX or Quaife all the way!
06-14-2007, 04:05 PM
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Josh Simon busted mid 14s with basically those mods. Brent in his spirit got into the 14s with similar mods....he had a flywheel i think too though. Although josh was in a sundance and brent was in a spirit.
06-14-2007, 04:57 PM
Engine: 3.0L V6
Well i guess we need to see this happen again, i thought the curb weight of the Spirits are close to the G bodies, 3000+lbs, which is why i figure it would need a bit of weight removed, i know a P body is gonna be quicker and might get 14's with those mods which is pretty nice.
Either way, i was just my 2 cents, not negative commenting. It is a good looking spirit either way. Unlike my multicolor daytona (dang ohio weather!  )
06-14-2007, 09:28 PM
Josh had 10:1 and I think we decided his race weight was 2700# or so when he went 14.2@ and had those 97mph traps.
v6 spirits in the later years (93-95) were only available as a "highline" package which means the most absolute base model possible.
about 2850 pound curb weight. Remove some weight, add a driver and you have a 3000# or less car.
Ive got video from bansheenut of my 14 second spirit running high 15's here @ high elevation.
My last trip to sea level I couldnt race because i took my good clutch and put it in the duster and at sea level the car made too much power for the stock clutch to hold on shifts.
Spirit doesnt have aluminum flywheel anymore but with a healthier longblock its actually running faster at high elevation.
Good driver, good 60', and 14's are there.
zzdust josh, josh simon, sean dalton, myself, and a few others have all pulled it off.
The people stuck in the 15's are just too heavy or not driving well.
When I went 14's my first runs were mid 15's with lazy driving and poor 60'. Increased the drivers side airshock pressure, dropped the 60's + drove balls out and easily broke into the 14's. When im driving with a good clutch Im chirping the tires shifting to 4th gear....even when my spirit doesnt have much power n/a and Im running 225 tires that are 25.5" in diameter.
06-15-2007, 12:55 AM
Engine: 3.0 V6
True i did leave out the 10:1 compression Josh was running...my bad. I didnt mean to sound negative Rouge ....sorry for that. Just saying that with some good driving 14s should not be an issue. Thanks for the input brent.
06-15-2007, 01:34 AM
#12
Attentive Forum Admin
My Ride: 87 CSX & 85 GLH
Engine: 2.2TII & 2.5N/A
I like it! The color and the black steelies?(my monitor is small and my vision sucks!) Nice Spirit.
-Clayton Dennis ~ Forum Admin
HAPPY 4th OF JULY!!! Enjoy the moment, and be safe
06-15-2007, 01:40 AM
#13
those are not steelies
06-15-2007, 02:04 AM
#14
I need to look into lacik? eye surgery I really cant tell.
Do you have a cardomain by any chance or a closer pic of the car? Would like to see the wheels to get the full picture of the car.
