Old 06-22-2007, 03:59 PM   #1
any one got spare turbo parts
like a rear manifold with out the exhuast outlet,? or a crossover pipe made for a t3
mopar3.0 is offline
Old 06-22-2007, 04:39 PM   #2
My Ride: 1990 Daytona ES
Engine: 3.0L V6
you need to post this in the parts wanted section, i didn't look yet, but best place to ask this kinda question. Good luck!
roguetrip is offline
Old 06-22-2007, 07:53 PM   #3
My Ride: '88 Plymouth Voyager
Engine: 3.0 V6
Try messing around a front manifold to fit on the rear, for a potential cheapskate way.
RoadWarrior222 is offline
Old 06-22-2007, 08:35 PM   #4
yea i was thinking about that my self, shoud just order a set of flanges and get it over with
mopar3.0 is offline
Old 06-22-2007, 09:04 PM   #5
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Performance Solutions, McMaster-Carr, a trusty welding machine, and a grinder/cutoff wheel will be your best friends for fabrication of a manifold.
mwinkle353 is offline
Old 06-22-2007, 10:22 PM   #6
My idea before was to just buy a flange. cut off the bolt tabs on a spare front manifold, and weld a new flange on so it will bolt correctly to the rear head in backwards fashion.
Old 06-23-2007, 01:14 AM   #7
MEOW!
My Ride: lebaron
Engine: 2.2L TI(ish)
Images: 138
or what you could do it make the rear out let the waste gate spot. and run it in to the turbo exhust pipe. and that way you dont have to malke a header or anything like that, just use a stock down pipe and make it bolt to the waste gate.
turbomini is offline
Old 06-23-2007, 03:06 AM   #8
ummmmmm. what?
All that to save $20 on the cost of a flange? and have a horrible setup?
Old 06-23-2007, 08:43 AM   #9
welding isent a prob ive got this
and the mig also has aluminum spool gun
mopar3.0 is offline
Old 06-24-2007, 01:53 AM   #10
MEOW!
My Ride: lebaron
Images: 138
Originally Posted by Ondonti
ummmmmm. what?
ok take the stock manifold and make a pipe that bolts on to the spot for the stock down pipe(after you cut that off) and make that the waste gate spot. and then put the turbo on the cross over pipe and run the exhuost out....
Old 06-24-2007, 05:31 AM   #11
Not really a new idea. Not really an idea that functions well either. Its been done before in a less ridiculous fashion.
WHen you have a manifold designed that horribly (asking exhaust to make a 180 deg turn and flow into something the wrong direction....
You dont also install an external wastegate that only covers the rear cylinders.
You might as well run an internal wastegate turbo.
Again, the whole idea makes no sense.
Old 06-24-2007, 12:28 PM   #12
MEOW!
My Ride: lebaron
Images: 138
yea i see what you mean now, i have only had one V6 and it ws in a mini van. so this i never have looked at the rear manifold at all.
Pay Day Loans | Loans | Tile Forum | Homeowner Loans | MPAA
Page generated in 0.38258 seconds with 13 queries
