Old 01-07-2008, 09:39 AM   #136
Re: P-body 24v updates
My Ride: 1993 dodge daytona
Induct: S/C
yeah thats pretty suky fuel. looks like thers water in it too.
m90daytona is offline
Old 01-07-2008, 06:31 PM   #137
My Ride: 92 sundance duster
Engine: 3.0L 24v
yeah, well thats gone, replaced with 4 gallons of 93 with lucas injector cleaner. now im down to wiring gremlins ARG! i hate wiring! replaced the injectors, found a short, and now the darn thing isnt getting power to the MS...*sigh* im done with it for the night...
Shadow24V is offline
Old 01-07-2008, 07:19 PM   #138
good luck. Thats what the old fuel that was in my duster looked like. I dumped it out when I put in the walbro. Then I cleaned out the tank with a hose lol. Had it totally removed so wasnt a big deal.
Ondonti is online now
Old 01-07-2008, 07:24 PM   #139
Engine: 3.0L 24v
lol, lucky. im not looking forward to when the pump or a fuel line goes as im predicting ill have to replace the tank, pump AND all the lines when that happens.....damn rust....
BTW can i say i ABHORE wiring!
Old 01-08-2008, 06:15 PM   #140
Engine: 3.0L 24v
messed around with the car some more, wiring gremlins still. Megasquirt has no power at the moment. Time to re-wire the car i guess, pull out the soldering gun and get rid of all the crimp connectors. Did i mention i HATE wiring? lol
Old 01-08-2008, 06:49 PM   #141
My Ride: '88 Shelby Z TII
LOL. I actually don't mind it! If it weren't for the fact that I don't like programming I'd probably be going for my EE instead of AE.
BTW, for the soldering I'd stick with paste flux and open flame soldering. The reason? It takes less time, you get just as good results, and heating up wires that thick is a PITA with a soldering gun, no matter the wattage.
Take your time, lay everything out you're going to need, make a plan of attack, and do it one wire at a time. It will actually go REALLY smooth if you do it that way. It might only take a weekend to do it all too! Once you're done you'll have a complete understanding of how every circuit is run in the car and will be able to chase problems MUCH easier!!
Good luck!! Don't give up!!!
Reaper1 is offline
Old 01-08-2008, 07:02 PM   #142
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
Good idea! Some of your wiring looks.... questionable. Perhaps grab a factory engine harness off a 3.0 mitsu car that fits close enough that way you will have factory connectors with a nice long pigtail. Also for your GM DIS coils a slick way to mount them would be to gut a GM DIS ignition module (the plate belows the 3 DIS coils) and wire the terminals inside straight through to the coils. I have done this (not installed yet) and it looks like it will be a slick way of mounting the coils that looks factory.
87turbodance is offline
Old 01-08-2008, 07:44 PM   #143
Engine: 3.0L 24v
cant grab a harness lol, im running Megasquirt so its a DIY harness. I am thinking of mounting the coils onto a tower bar when i get/make one, or something, dunno yet, gotta figure out what im gonna do with the M90 and a custom manifold later :-D
Old 01-09-2008, 07:22 AM   #144
Engine: NA 3.0
I know you're running MS. I mean buy a harness to replace some of your questionable engine wiring then you can have a common spot to hook your MS wires into it. I just felt it would be a more reliable solution then what I've seen of your current wiring. I think I remember you using the same colour wiring for everything - that can be a bit confusing when diagnosing problems.
Just a thought I had that I wanted to pass along.
I have been building my MS for a year now (no time to finish it) and I plan to use most of the original 3.0 harness and just tie into the wiring where the SMEC used to be and run a simple harness into the inside of the car from there for MS. This is how I wired my Sundance - it worked well except when water came into my car when it rained and would get into my MS! and would shut down the MS processor for like 2 hours until it dried out.
Old 01-09-2008, 11:01 AM   #145
Engine: 3.0L 24v
interesting, well, im gonna start re-wiring the car today so hopefully i can get this figured out.
Old 01-09-2008, 06:26 PM   #146
Wtf!?!?
Engine: 3.0L 24v
ok, spent the afternoon redoing nearly all the conections with solder and shrink tubing. found the issue, the primary ground had pulled off the connector. got her to fire, but shes running so godawfully rich i cant figure it out for the life of me.
i can IDLE with a VE of ONE and an A/F of 7 to 8 :1, and it will hunt badly but still be running on a VE of ZERO; i cant figure it out. all the wiring is not shorted, is fine but i almost think those back injectors are not shutting again. *sigh* i just want the freaking thing to run damnit!
Old 01-09-2008, 08:05 PM   #147
Did you clean or replace the spark plugs?
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 01-09-2008, 08:49 PM   #148
Engine: 3.0L 24v
the spark plugs were new when i couldnt keep it running due to the stuck injectors. back bank was pristine clean, and the fronts were only slightly carbon touched.
here is it idling at about 800rpms. sounds like crap, rough and vibrates bad.
compared with it running 2 months ago here
Old 01-09-2008, 09:08 PM   #149
If the spark plugs have been hit with liquid fuel, they need to be cleaned with a torch (as Brent has mentioned) or replaced.
Edward Kelly
c2xejk is offline
Old 01-09-2008, 09:12 PM   #150
After listening to the video, one other piece of advice, make sure the spark plug wires are routed to the correct cylinder... I miss wired Stein's once and it idled ok, but as soon as you tipped into the throttle much it would buck something awful...
Edward Kelly
c2xejk is offline
