Old 05-14-2008, 10:51 PM   #406
Re: P-body 24v updates - Stupid College kids!
My Ride: 95 Caravan SE
Originally Posted by Shadow24V View Post
well, i got called out of my 9am class because my car was found in an irrigation ditch up near where i parked. Some asshole kids or someone popped my car into neutral and pushed it UPHILL into the ditch and stole my rear license plate.
OMG! How did I miss this?
Shadow, it looks like the boys are afraid of you. They just can't face the idea of you kicking their little butts. It is going to be all the sweeter now, when you do so again, by an even larger margin than before.
Hang in there.
lookin is offline
Old 05-14-2008, 10:58 PM   #407
i had gone up to check on the car a few days before this happened and i hadn't closed the door all the way the time before so my battery was dead BEFORE this happened :-p
I just read about what happened. I missed it somehow until tonight.
It may be, that they were PO'd, when they couldn't hotwire it and steal it.
If I wasn't broke I would buy you a good car alarm and an industrial strength TASER bullet riffle.
lookin is offline
Old 05-17-2008, 07:17 PM   #408
My Ride: '93 Dodge Shadow ES
Engine: 3.0 v6
Okay Shadow,
You've been crowned Web-Wizzer, or whatever you've been studying. Now whats up with your poor neglected car?
You know that could have been a cry for attention by old Blue. Cars get cranky when they're ignored. She might have used the last few amps in the battery to hurl herself over that cliff.
Leaving her door open could have been the last straw. Cars are people too!
SpeedyEd
SpeedyEd is offline
Old 05-17-2008, 07:48 PM   #409
My Ride: 92 sundance duster
Engine: 3.0L 24v
lol, thanks lookin and ed
she'll be getting a lot of attention starting tomorrow when i start to pull the motor/trans out. then ill see how bad the damage is in a couple days...
Shadow24V is offline
Old 05-17-2008, 07:52 PM   #410
I am on the edge of my seat Shadow!
I think Ed is on to something. I sweet talk my van constantly, and so far she just keeps getting better and better. That is even despite my best efforts to screw things up.
lookin is offline
Old 05-17-2008, 07:56 PM   #411
Engine: 3.0L 24v
lol, ill have to give her a wash and bring her something nice
Old 05-17-2008, 07:56 PM   #412
Engine: 3.0 v6
Hey,
Before you pull the engine, check the externals (water pump, alternator, idlers, etc.) unless you're making up for past misdeeds. How about that pulley you welded the crank pulse wheel to?
SpeedyEd
SpeedyEd is offline
Old 05-17-2008, 08:03 PM   #413
Engine: 3.0L 24v
alternator is good, same with PS pump, water pump was replaced whet i put the motor in...
the cranc pully is solidly bolted to the crank still, but ill double check it tomorrow
Old 05-17-2008, 08:29 PM   #414
Engine: 3.0 v6
Don't forget the idler pulley .That bearing can make that rolling rumble sound.
SpeedyEd
SpeedyEd is offline
Old 05-17-2008, 08:34 PM   #415
Engine: 3.0L 24v
ill fire it up w/o the alternater belt and see...
Old 05-18-2008, 11:15 PM   #416
Engine: 3.0L 24v
ok, i posted this over in the suspension area, but i though id post it here too. I was reviewing my vids from the track today. one thing i did notice was how much squat i was getting off the line with the stock rear springs and original '92 shocks. these will be replaced this summer and my coilover suspension finished. i dont have a clue what the spring rates are on my coilover kit ($20 ebay/china kit) but so far its been good on the front. A little stiff (small bumps skip cds, but i also have a cheapo walmart stereo). ok onto what i need some advice on:
in addition to the rear coilovers, i would like to add a sway bar to help handling. Ive also read that if i lower my p-body, i have to adjust the panard bar which makes me think i should just make an andjustable one and replace the U-channel original one. would changing to a stiffer panard bar help in any way? im looking for overall balance, not a straight drag car
the other question is rims/tires. my 195/60R15 cooper all seasons dont have much grip, especially off the line. i can only launch at 1500-1800 rpms as anything more results in excessive wheelspin. I was hoping to find some SRT-4 rims (17x7) and get some good performance tires for them. Would the larger rim size have an affect on the car? (rotational inertia etc) and what would some other recommendations be if i cant get SRT-4 rims? (rim size, width etc)
thanks in advance.
Old 05-19-2008, 11:01 AM   #417
My Ride: '88 Shelby Z TII
I've not personally run one (yet), but I hav friends who do have the tubular adjustable panhard bar on their cars. It is a nice peice, but I can't attest to how it effected anything else becuase they don't really drive their cars that hard. I've heard from other people that the feel of the rear of the car through transistions is a lot better. Not only that, but you don't have to worry about buckling the wimpy stock peice(something *I* do worry about!). When you lower the car, the rear axle will move slightly out of center woth the rest of the car due to the suspension geometry. It won't effect the car in a straight line, but in corners it could mess it up a tad, but unless you measure the before/after, I honestly don't think you'll notice that big a difference with it being centered or not by that small amount.
What pressure were you running in your tires when you were racing? I can tell you that I used to run 24-22psi in mine and launch right around 1700-2000rpm(it was an auto car) and get pretty decent 60' times for the tires I was running. The larger wheel/tire combo *might* slow you down depending on their weight and what tires you run. I think that the 17's are a good compromise between weight and cornering performance along with ride. I don't know how they fair in straight line acceleration. I think that you should use those on the street and auto-x, HPDE events, whatever, then swap to the 15" wheels with some good drag slicks on them for the straight line stuff. I know there money involved with that sort of thing, but that's the best option. The next best would be to just find the tire that best suits your purposes and go with it.
HTH...
Reaper1 is offline
Old 05-19-2008, 08:47 PM   #418
Engine: 3.0L 24v
i ran stock pressure (35lbs) the first day at the track when i got my best time of 14.96, i was playing with tire pressure the 2nd day, and was down to about 20 lbs for the run i blew on. didnt get a good read on the 20lb tires though as i bogged off the line.
Im looking at KYB gasadjust shocks for the rear and GR-2s for the front, im hoping that will help out some, esp with the stiffer rear springs.
as for the panard bar, does someone sell one already? and what do you think of a rear sway bar on a P-body?
Old 05-19-2008, 09:03 PM   #419
Engine: 3.0 v6
Hey Shadow,
I put an Addco rear sway bar on my '93 ES. It helped the steering response & cornering.
I bought the KYB struts & shocks to replace the Monroes. Haven't made the switch yet. Also got the Eibach springs & will do them together.
Don't know how the low rider look will work in the snow, but I have other tires.
SpeedyEd
SpeedyEd is offline
Old 05-19-2008, 09:04 PM   #420
My Ride: 1990 Daytona
Engine: 3.0L V6
Going aftermarket Chris sells a adjustable panhard bar:
http://www.csracer.com/panhard.html I asked him a week or so ago and he said was what 3 weeks backorder though. Looks like a very good unit though!
roguetrip is offline
