05-30-2008, 08:26 AM
#496
Re: P-body 24v updates
My Ride: 87 Daytona Pacifica
Engine: 2.2 Turbo
Hey I have the exact AFPR with no instructions either, did you find out how it works
05-30-2008, 04:31 PM
#497
My Ride: 92 sundance duster
Engine: 3.0L 24v
yeah, im not going to do anything til i have my cousin physically inspect the rod caps. is there any way to put pistons in from the BOTTOM of the block? if i can do that, ill pull the rods and do it that way. trying to avoid $60 HGs and $40 head bolts
05-30-2008, 07:28 PM
#498
Engine: 3.0L 24v
measured the #1 rod ID - 2.081-2.085, crank measured 1.965 on 90* rotations, so from what i can tell, the #1 (worst looking rod) is still dead on spec.
all six crank rod journals measured 1.965-1.967 *shrug* ill measure the other rod IDs tomorrow.
05-30-2008, 07:38 PM
#499
My Ride: '88 Plymouth Voyager
Engine: 3.0 V6
I've heard of it done on other motors, I'd imagine you might have to ream out the whole bottom of the bore though, and you've got the angle of the vee to contend with, gotta be easier on I4s.
05-30-2008, 07:45 PM
#500
Engine: 3.0L 24v
yeah, took a look at the bottom end, there's NO way i can get the pistons out the botom. but with the rod and crank being within spec, i wont have to pull the rods
05-30-2008, 08:46 PM
#501
My Ride: '93 Dodge Shadow ES
Engine: 3.0 v6
Hey Shadow,
Double check your rod bore measurements,they appear smaller than stock(2.081/2.085 vs 2.0866/2.0868). And you're going to measure down to ten thousandths.
Your #1 journal at 1.965 is under by 0.0027/0.0035, that's gonna be loose with standard Brgs.
SpeedyEd
05-30-2008, 08:56 PM
#502
Engine: 3.0L 24v
where did you get your #s anyways? just curious. Its also an inexpensive digital micrometer.
05-30-2008, 08:59 PM
#503
Engine: 3.0 v6
From the Clevite bearing catalog. It also listed two rod forging #s, 72G & 72W.
SpeedyEd
05-30-2008, 09:26 PM
#504
Engine: 3.0L 24v
which 6g72 are you looking it up for? an do you have a link?
05-31-2008, 07:30 AM
#505
Engine: 3.0 v6
Hey Shadow,
A link? Man, I'm from the last century. I have the catalog at work. The bearing info covered all the the 3.0s, SOHC 12 & 24v & DOHC. I'll look for a link to Clevite, otherwise I'll bring the book home Mon.
SpeedyEd
05-31-2008, 08:52 AM
#507
Engine: 3.0 v6
Hey Shadow,
I didn't find the data on the Clevite site, but they have recon rods listed. The part # is CR 1104. No price listed, but I can check Mon.
And what about the tangs? Are they wiped? If not, the brgs. didn't spin or move.
SpeedyEd
Just looked at your photos again, & the rod brg. tang looks ok. Was there some sign that the brg spun in the rod?
05-31-2008, 09:21 AM
#508
Engine: 3.0L 24v
Tangs on all bearings LOOK fine (dont know how new ones look so *shrug*) re-checked the rod journals on the rank today, 1.968 on all, dead nuts on spec. being tired, sunburnt and fatigued probably didnt help last night lol. i also plastigauged the #1 rod clearance, .001 (variance is .0008-.0019) its looking more and more like nothing is wrong with the rods or crank  ill plastigauge the rest of the rods sometime today
05-31-2008, 10:18 AM
#509
Engine: 3.0 v6
Ok,
So much for the good news. Now you have to find the real cause of the noise.
I'm glad the bearings didn't spin, 'cause thats expensive.
Time to stop sunning & get to work. There's tires that need to get smoked!
SpeedyEd
05-31-2008, 11:39 AM
#510
Engine: 3.0L 24v
lol, yeah i lounge around in the sun and leisurely work on my car (i WISH)  ill reassemble everything, new bearings, new oil pump, and see if i still have a noise or not *shrug* i have all summer anyways...
EDIT: btw, the clearance was with the WORN bearing too
