06-23-2007, 10:20 AM
7th injector for built 3.0's?
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
I've been reading about building 3.0's with things like cams and ported heads and like that, and from what I've read it sounds like the ECU can more or less compensate at partial throttle openings, but at wide open throttle it goes to its preprogrammed map and ignores the O2 sensor.
So I was thinking. If your engine has enough mods to boost its airflow substantially, how about wiring a 7th injector to turn on at WOT like the Turbo cars can do with a 5th injector over a certain amount of boost?
Seems like it'd work to me. It may not be a precise air / fuel ratio but it's better then leaning it out too much.
