Old 07-01-2007, 09:02 AM   #1
24 valve questions
is there much flow diffrence between the sohc 24 valveheads a dohc 24 valve heads
my buddy had a 3.0 24 valve in hos avenger he up graded to wiseco psitons and rods and has the old low km pistons and the sohc 24 valve heads from the 2.5, thining about gettng another sohc block and building a 24 valve ,
and the dizzy on the 2.5 24 valve does it have optical pick up?
mopar3.0 is offline
Old 07-01-2007, 12:44 PM   #2
I am not sure there is much flow difference between well ported 12-valve and the stock 24-valve setup...
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 07-01-2007, 01:28 PM   #3
they made around the 200 hp mark stock right?
mopar3.0 is offline
Old 07-01-2007, 06:44 PM   #4
My Ride: 92 sundance duster
Engine: 3.0L 24v
they are QUOTED at 205hp and 205tq. in practicallity, a 3g will dyno around 170s to 180s in a manual, 160s to 170s in an auto. thats with a factory tune though. with a standalone or a reflash, you COULD maybe get 200whp in factory trim.
headwise, the DOHCs outflow the SOHCs in stock trim.
and the 3.5/3.0/2.5 24v SOHC heads are all interchangeable, altthough the cams differ. there is no opto sensor in the dizzy, there is a Camshaft position sensor in the dizzy (VR sensor) and a crank angle sensor that triggers once per TDC event.
were you planning on boosting the 24v? (also mind you it doesnt bolt in 100%) what did you have in mind?
for some reading see the following threads:
24v 3.0 swap
24v updates
Shadow24V is offline
Old 07-01-2007, 08:25 PM   #5
no boost, just use the stock 24 valve pistons and ahd sohc 24 valve heads he has oh my stock 3.0 crank and block. i wouder could i use that vr sensor to trigger my ms, that engine in a spirit should pull like a stink,even in sotck trim
mopar3.0 is offline
Old 07-01-2007, 08:44 PM   #6
Engine: 3.0L 24v
so you want to use the 24v heads and pistons in a 12v block?
and if you think a 24v will pull like stink in a spirit, i got mine in a P-body duster!
Old 07-01-2007, 09:21 PM   #7
yes the 14 valve heads on a 12 valve block, i bought another engine with only 100.000 km. because my 150k engine is starting to burn oil, but seeing he has these parts i was thkning about
trying this, i was thinking the 12 valve timming belt would be ok,
i assume the cam gears are same size, , not sure if they the same distance from the cylinder head or not,.
the spirit is getting lighter and lighter every day, the tourke my buddies avenger got is something else, i couldent get over the way the auto lights the tires
mopar3.0 is offline
Old 07-02-2007, 04:08 PM   #8
Engine: 3.0L 24v
you can bolt the 24v heads onto a 12v block, and with the 4v reliefed pistons thats out of the way. you would also need the upper and lower intakes, and some custom headers as the exhaust ports and bolt pattern are different on the 24v heads. the coolant exit is also moved to the drivers side, and you would need the TB too. and some way to control timing as the dizzy cannot be rotated at all to affect timing. (OBD-II motor)
Old 07-02-2007, 05:41 PM   #9
Considering all that has to be done to use the 24v heads, ported 12v heads are cheap and easy.
The set on my van flowed 205 CFM, the set I am working on right now flow 235 CFM...
Edward Kelly
c2xejk is offline
Old 07-02-2007, 07:44 PM   #10
cant i just use the ms to set my timming?
mopar3.0 is offline
Old 07-02-2007, 08:40 PM   #11
Engine: 3.0L 24v
are you running a MS? if so, you can trigger off the neg. side of the coil for ign. advance.
the whole project wont be easy but *shrugs*
0 Credit Cards | Adverse Credit Remortgage | Loan | Free Insurance Quotes | Dental Information
Page generated in 0.41508 seconds with 13 queries
