09-03-2007, 10:11 AM
The two engines are not even in the same family so there is no point in contemplating parts echanges between the two. The 3.3 engine is a pushrod engine made my Chrysler. The 3.0 (6G72) is an overhead cam engine made by Mitsubhishi. That discussion pretty much ends at the throttle body.
Can you put the whole 3.3 in your Daytona? More than likely yes. You would just need to swap the electronics, accessories, and brackets along with it along with a trans that fits the 3.3 (you can't bolt the A543 to the 3.3 and the autos have different bell housings so you'll need one specific to the 3.3). There are probably some other minor issues but I would expect it to be failry straight forward because some of the cars and vans came in both the 3.0 and 3.3 configurations. The only gotcha that jumps out in my head is that the motor/trans mount brackets may be different between the cars and vans ...maybe someone else can speak to this. In any case, this should be easier than many of the other swaps that have been proposed and undertaken in this forum.
