Old 09-16-2007, 01:05 PM   #1
hay Ondonti
just to give you some inspration, a local guy built a 3.4 turbo cavlaier
hes running close to the same trap speeds as you, and close on the 1/4 too i think he just hit the dyno and made
298.7 WHP @ 5000 RPM
415 Wheel FTlb at 4300 RPM
at 11 psi
i wounder what your numbers are at your 5 psi
mopar3.0 is offline
Old 09-16-2007, 01:17 PM   #2
Well I will have to get this motor together again properly. Intake manifold will probalby not be done again for awhile.
I did drop of my megasquirt with bansheenut and will see if he fix the wiring on the back of the board to match the distributor setup I need to use.
I am guessing only 250whp and 300ft/lb @ 5psi because of the elevation and my low compression. Maybe a little less.
Old 09-16-2007, 01:30 PM   #3
i dident even know you had your can on the dyno, hes running ms also fully tuned. i think there more hidden power in your little 5 psi lol, cant imagine 11
im sure the mega squirt will make a diffrence
mopar3.0 is offline
Old 09-16-2007, 04:15 PM   #4
nono, no dyno.. Im GUESSING
Based on the numbers from the track and assuming my trap speed was a little bit low because of shifting into 3rd gear @ like 20-30mph causing a bog.
Old 09-16-2007, 08:19 PM   #5
Sorry Brent, but your trap speeds are high for your et, not low. lol
Ubmbass is offline
Old 09-16-2007, 08:21 PM   #6
I meant low for what the car should have done. Wasted a lot of time @ 2000 rpms in 3rd gear on both good passes I made.
Remortgages | Loans | Electricity | Remortgages | Credit Reports
Page generated in 0.81363 seconds with 13 queries
