Old 09-22-2007, 06:56 PM   #1
Are rings supposed to be able do this?
Are the piston rings supposed to be able to be twisted like this???
While I am showing things... Here is the #3 rod. Hard to tell from the picture, but the bearing it was spun bad and the rod is now warped. The cap will no longer go back on...
Here is the one of the spun bearings.
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 09-22-2007, 10:50 PM   #2
My Ride: 95 Caravan SE
Holy crap!
How in hell did you do that ED?
lookin is offline
Old 09-23-2007, 01:10 AM   #3
not as bad as two of my bearing experiences
I wouldnt even try to machine that rod. i learned from that mistake.
What did you do when you took that ring off? just looks like you bent it?
You sorta have to tell us some crazy story to go along with the picture so i dont think things like that
Old 09-23-2007, 06:30 AM   #4
Dang, I ain't never seen one do that.
Force Fed Mopar is offline
Old 09-23-2007, 08:13 AM   #5
The bearing was spun during a drag run last year. At first I thought I had a lifter ticking. During the teardown I realized that was the case. Rod Bearing #2 was "mildly" spun and Rod bearing #3 was majorly spun. I suspect #3 went first and took #2 with it since they share an oil supply
The #2 rod was repairable. Rod #3 is indeed toast and has been replaced.
The crank has been turned. The rod journals had to be turned down .020".
During reassembly this weekend, Mike attempted to break one of the top rings to clean the ring grooves. The second ring broke like expected, but the top ring just bent. You could probably tie it into a pretzel.
I suspect this is why my machinist recommended plasma coated rings. I opted for chrome rings which are supposed to be slightly better. The rings (both top and second) are gapped to 0.025"...
Edward Kelly
c2xejk is offline
Old 09-23-2007, 11:23 AM   #6
Oh ... so that's what happened to that ring. I thought it somehow twisted like that in cylinder, and I could not imagine how it could.
lookin is offline
Old 09-23-2007, 04:04 PM   #7
i would run a larger 2nd ring gap on any boosted car then you have on the top ring.
Mortgage Calculator | Credit Card | Masini | Free Ringtones | Car Accident Attorney Los Angeles
Page generated in 0.68827 seconds with 13 queries
