Old 10-02-2007, 03:14 PM   #1
3.0turbo allwheel drive
My Ride: 1989 lebaron gtc
Engine: 2.2turbo t2 shelby
my plan is I have a 55dodge truck i just bought a montero frame to put under it what i would like to do is turbo the 3.0 and leave the factory running gear in it i could leave it awd then for when i want to launch. my uestion is what would be a good twin turbo , or single turbo setup be i'm aiming for 500hp or more of course and somewhere around 400 foot pounds i have everthing i need to build it I have a speed shop at my disposal ,another thing what will the factory lower end hold . I would like to stay within safe rpm levels for the timing belt i dont know what you can turn a 3.0 to reasonbly . I guess my big uestion is turbo ? all of my time with turbos has been spent on fourbangers so i don't know for sure what would work to get this horsepower getting the boost is easy what concerns me is the exaust side not flowing enough
I have played around with my desktop dyno a little but I dont trust it and wanted to get some opinoins for people who have played with the 3.0
Hemi417 is offline
Old 10-03-2007, 09:35 AM   #2
Re: 3.0turbo allwheel drive
anybody
Hemi417 is offline
Old 10-03-2007, 09:54 AM   #3
My Ride: 95 Caravan SE
I am sure somebody will answer you eventually. Hang in there.
lookin is offline
Old 10-03-2007, 07:55 PM   #4
Do some research on how to read turbo compressor maps and that will help you determine which turbo will be appropriate for a single or twin turbo setup. When you say 500hp, do you mean 500 wheel hp or crank hp? Someone correct me if I'm wrong, but I think the stock bottom end with forged pistons is good for a reliable 450 crank ft-lbs of torque?
Turbo3.0 is offline
Old 10-03-2007, 07:58 PM   #5
My Ride: 1994 Caravan turbo!
Images: 4
"sounds possible but not probable"
- mythbusters.
big_P is offline
Old 10-03-2007, 11:22 PM   #6
Your not gonna get 500whp with smallish turbos without getting 600+ftlb of torque in my opinion.....unless you do some magic to make the valvetrain handle high rev's and get some good flowing heads from Ed Kellly.
Old 10-07-2007, 10:53 PM   #7
Thanks for the help
I was looking for 500hp at the crank as far as i'm concerned the more tq
the better, that was just seemed fairly reasonable accordong to my desktop ( see why I wanted to ask somebody who has done it before) i'm going to be lucky to hit 3200lbs with the truck body I was going to lighten the body as much as possible but it's still pretty thick iron. . realibility is not as much of an issue with this project but would like to be able to take a 300mile trip with it so i would like to build it right but it doesn't need to be bullet proof (weekend warrior)
Hemi417 is offline
Old 10-08-2007, 12:59 AM   #8
Good luck keeping the Montero AWD system together with that kind of HP/torque.
Swapping a First/second gen Dakota frame seems to be a better way to go....if you only do RWD and not AWD.
Justa thought.... Sounds like a cool project though.
440trk is offline
Old 10-08-2007, 08:43 AM   #9
why dont you just swap a twin turbo dohc 3.0?
mopar3.0 is offline
Old 10-08-2007, 01:46 PM   #10
Well I dont thing anyone knows the capacity of the montero system. Maybe you can get lucky.
Old 10-09-2007, 10:41 AM   #11
well my hope is that because of the turbo and automatic the power curve will be smooth enough that it will live for a little. while I dont think it's bullet proof by any means what do you guys think i'll have to do to the lower end to get the horse power , tq range I want. i figured i would run 12psi like I said this is all figures from my desktop so any input from people who have experaince with turboing 3.0 will greatly be apprec. I have done a little resarch and I think I want to run twin te04s mitsu that will hopefully put lag up there a little bit to save the tranny I think the rest of the drive train will hold I saw a toyota with a 440 that held untill he sunk it in the bottom of the river for about 6months so i'll try it you dont know till it breaks
Hemi417 is offline
Compare | Debt Management | Debt | Problem Mortgage | Myspace Layouts
Page generated in 0.99554 seconds with 13 queries
