You spent the money on Cam Gears and don't know what to do with them?!?
The gist is:
If you advance your cams (rotate them clockwise with respect to the sprockets so the valves open and close sooner), you will rock your power curve downward on the RPM band.
If you retard your cams (rotate them counter-clockwise with respect to the sprockets), you will rock your power curve upward on the RPM band.
This also gives you the ability to equalize them if for some reason they aren't equal due to factory tolerances.
When speaking of advancing or retarding, it doesn't take much rotation at all (think fraction of a tooth). as accurate as
As Brent said... 1st you need a degree kit.
As for what to do once you've got that, I wrote up some instructions awhile back. They are mostly accurate but not 100%. Regardless, they should be good enough to get the point across.
Degreeing your Cams
Have fun!
Mike Mulhern
Kelly-Mulhern Performance
