Old 03-14-2008, 10:03 AM   #121
Re: Who sells 3.0 Magnacore kv-85 wires? part # 6514
My Ride: 95 Caravan SE
Try this Summit Terminals list too.
Male/HEI, Ignitions & Electrical - summitracing.com
Are these the specific ones you need? If the boots wont fit, individual coil packs, I think the terminals will, and if you already have the right boots you could combine them.
MSD Ignition 8849 - MSD Replacement Spark Plug Wire Boot and Terminal Kits - summitracing.com
lookin is offline
Old 03-14-2008, 08:27 PM   #122
My Ride: 92 sundance duster
Engine: 3.0L 24v
i had a bit of an idea on the 6 hour drive home today. i still have the magnecore wires from before i went DIS and i have the HEI terminals on my current wires, i MAY be able to de-crimp the MSD wires and switch them over to the Magnecore ones and have just enough length....something to look at over this week
but to answer your questions, i have a 2000 Eclipse GT v6 motor and regular GM DIS coilpacks (HEI boots)
Shadow24V is offline
Old 03-15-2008, 12:41 AM   #123
That may work. I am not so sure that reusing crimps is a good idea though.
lookin is offline
Old 03-15-2008, 03:24 AM   #124
My Ride: '88 Shelby Z TII
I've done it in a pinch with the Magnecor wires when I had the ends pull off and no other option. I cut off the bad section of wire, stripped off enough to exopse a good section of the core and hand crimped the terminal back on with some pliers. It worked well enough that it didn't come back off....
Reaper1 is offline
Old 03-15-2008, 03:31 AM   #125
well how expensive are those MSD connectors?
Old 03-15-2008, 08:04 AM   #126
Engine: 3.0L 24v
Summit lists a 9 pack for about $13 (before shipping) and ebay is similar with usually a $10-$14 shipping cost...
Old 03-18-2008, 09:58 AM   #127
Thanks. That settles that then.
lookin is offline
Old 03-18-2008, 07:02 PM   #128
Engine: 3.0L 24v
well, i was bored tonight while waiting for my car to get an alignment done (2nd day waiting grrr ) and decided to take apart the distributor end of one of the magnecore wires i bought for it last year. i found out it was a single crimp foldback job with a bend in the metal connector to get the 90* into the distributor. i also noticed what looked like arching or some other form of brown scoring on the wire. i also took pictures of the rubber boots on the spark plug shafts taht caused me so much grief when they pulled off and were stuck on the spark plugs IN the head.
im pretty sure i can trim off less than an inch of the wires and replace the connectors with the Summit HEI connectors (if i can get the double crimp ones) and use these wires again. they dont have much use on them at all and would look cleaner in the engine bay than the MSD ones currently in use, plus i think the MSD ones are 8mm and the magnecores are 8.5 mm
boot off, can see the tip of the conductor past the end of the crimp
foldover again (little fuzzy)
taken apart, see the bend in the conductor
the brown scoring
the boot issue
current setup
Old 03-18-2008, 10:30 PM   #129
Holy crapload of wires batman!!!
Reaper1 is offline
Old 03-23-2008, 12:57 AM   #130
Those are not Magnacore wires. Those look like OEM wires.
the brown scoring
the boot issue
current setup
Magnacors look nothing like that wire.
Old 03-23-2008, 08:39 AM   #131
Engine: 3.0L 24v
huh, guess one got pulled over on me. MagStar is a totally diff company, apparently specializing in MARINE wires. In addition, the wiring markings and color are different. Thanks for the heads up on that Brent, never woulda caught that myself. guess ill have to ask magnecore to make a set with the HEI ends for me
Old 03-23-2008, 09:47 AM   #132
If you are making a project of it, you might try the MSD connectors.
Its magnacor with no E on the end. I usually misspell it (like in the thread title).
Old 03-23-2008, 09:55 AM   #133
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
Did you try calling them yet? I may next week just to see about the connectors
speeduphoria is offline
Mortgage | Mortgage Calculator | Mortgages | Advertising | Online Loans
