Old 02-21-2008, 12:37 AM   #1
What is a good coil to use?
My Ride: Laser XT
Images: 1
What is a good coil to use on the 3.0? I have NGK plugs, new stock plug wires and a big Accel (I think thats what it is) coil wire. I have one of those big can type coils found on a turbo Daytona, that is Accel too I think. Are those any good? What is a good one to find at the junkyard?
jory is offline
Old 02-21-2008, 01:39 AM   #2
Re: What is a good coil to use?
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
Im using a MSD Blaster 2 coil....the can type. Again....go Brents route. Ford 5.0 coil.
irocelectric93 is offline
Old 02-21-2008, 03:47 AM   #3
My Ride: 95 Caravan SE
I use the stock Dodge coil, for their 5.9L trucks, part number 8228.
It looks, just like our stock coil, except it has a male output connector.
It fits out coil mount perfectly.
It offers 12,000 volts more than our stock coil.
That and a MSD 6A cd box, will cook you fried rice, for breakfast lunch and dinner.
lookin is offline
Old 02-21-2008, 01:09 PM   #4
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
I've had nothing but great results with just your standard Ford 5.0L Mustang coil. They're cheap and pack one hellova punch. The only other coil I liked better than the Ford coil was the Crane Cams LX-92 coil. But on these 3.0L motors, once you have a good ignition, you don't need "the best". Unless you're turbocharged, I wouldn't suggest anything more than a stock replacement Ford unit or a Blaster SS coil from MSD.
mwinkle353 is offline
Old 02-21-2008, 01:46 PM   #5
My Ride: Laser XT
Images: 1
Ford 5.0 it is then.
jory is offline
Old 02-21-2008, 02:07 PM   #6
the 5.0 coil requires finding a way to mount it! My method is sorta goofy.
Old 02-21-2008, 03:52 PM   #7
Engine: 3.0L V6
Simple bracket bolted to the front of the intake plenum and you're in business.
Or, modify the stock one with a plate large enough to mount the ford coil onto it.
My two chosen methods. But the second one actually works better, if you don't make the first one out of thick enough material.
Old 02-21-2008, 11:47 PM   #8
I did #2 but I alaways thought it looked goofy. Especially because the bolts I used were way to long.
Old 02-23-2008, 12:36 AM   #9
My Ride: Laser XT
Images: 1
What is the output of the stock coil versus the Ram coil and the Mustang coil?
jory is offline
Old 02-23-2008, 11:01 AM   #10
Engine: 3.0L V6
Don't worry about the volts of a unit. It's the amps that make the spark hot as heck.
I won't use anything under 350mA. And I believe the Ford unit is around 400mA. The MSD Blaster SS coil is around 300mA.
All three coils throw over 38k volts.
Old 02-23-2008, 03:12 PM   #11
So does anyone think aftermarket 5.0 coils can be better then the stocker? Reaper has me confused about their claims of higher dwell time etc since that is ecu controlled?
Old 02-23-2008, 06:43 PM   #12
My Ride: '88 Shelby Z TII
Sure..I think some of them can be better than a stock one. I didn't mean to confuse you on the dwell time. Sorry about that.
What has you confused? I'll try and clear up my thoughts a bit if it might help...
Reaper1 is offline
Old 02-23-2008, 07:55 PM   #13
5.0 Ignition Products
Originally Posted by that site
The 5.0 Dyna-Mod has more electronic dwell in it over a stock module to provide more coil saturation time. This extra dwell time allows the coil to produce a more intense spark. Improves throttle response and low end power. Mounts in the original factory location without any modifications.
Part #000555 (84-93) $69.95
Part #X000555 (94-95) $69.95
This is what I was interested in you explaining.
I am probably going to buy another stock 5.0 coil for my spirit because I am messing around with passing emissions on my spirit while it visits Seattle (where it is registered )
Old 02-23-2008, 08:45 PM   #14
My Ride: 1990 Daytona ES
Engine: 3.0L V6
here is a good read about ignition system
Electronic Ignition Overview
roguetrip is offline
Old 02-24-2008, 02:04 AM   #15
Hmm...I'll have to investigate this. It sounds like they over ride the stock dwell time though with some sort of electronic control...
Reaper1 is offline
Anime | Mobile Phone | Credit Counseling | eHarmony | Best Credit Cards
