Old 02-21-2008, 05:30 PM   #1
water bypass return
from the water pump can i run this in to any part of the coolant system do it need to be in the return or supply side?
mopar3.0 is offline
Old 02-21-2008, 05:50 PM   #2
Re: water bypass return
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
The only bypass/return I know of comes out of the thermostat housing and routed into the pump's intake pipe under the intake runners.
Is this what you are referencing? If so, you can put it anywhere that goes into the pump's inlet. Heck, you can tee it into the heater core's return.
mwinkle353 is offline
Old 02-21-2008, 06:11 PM   #3
ok, that was kinda my plan, gona mount the stelth lower with the termostart housing on the drivers side
mopar3.0 is offline
Old 02-21-2008, 07:06 PM   #4
Engine: 3.0L V6
that's how I was going to do it before. However, I was going to use SS hose and clamp it to the lower intake to head bolts. Just running it from the driver's side to the pass side, to the stock bypass location.
Old 02-21-2008, 07:10 PM   #5
yea i may do that , i was also thinking about fabbing up a 1.25 copper pipe that will run along the front of the intake and come out somewere close to the stock upper rad hose location and soldering in a nipple into that for the bypass,
i work at refrigeration so have lot of pipe and bends and silver solder which is very strong
mopar3.0 is offline
MySpace Images | Mortgages | Free Advertising | Hotels | Internet Advertising
Page generated in 0.32860 seconds with 13 queries
