02-29-2008, 09:40 PM
#17
Re: Alternatives to custom cals for the 3L V6
My Ride: 94lebaron 87sundance
Engine: 3.0l/2.2-2.5tubro360
any one tried a map adjuster works by changing the 5v ref voltage , saw the over on a jeep 4.0l site they had plans on how to make one
03-01-2008, 09:12 PM
#22
03-01-2008, 09:42 PM
#23
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Ok folks, I've been standing on the outskirts of this thread. And it's about time I put my 2 cents worth in here.
The cost/effectiveness of a piggyback or intercept/signal modifier had it's pro's and con's.
First:
The Speed density system of our PCM's rely on vacuum and barometric pressures for initial calibration (pre-start) parameters. Once we start messing with this setup, all goes out the window.
Second:
Along with the pre-start, once you modify the map sensor's values to the stock PCM calibrations, you may be able to adjust a percentage of fuel adjustment (but only at the risk of altering the ignition output (ie stock calibration's internal map) and chance over or under compensation of timing.)
You can add a second controller (or just use a single, more expensive unit that allows programable ignition advance/retard). But at wich point would it become more cost effective to use a stand-alone system?
These are just two of my concerns with "band-aide" solutions to fuel/ignition calibrations. I have plenty more. But I reserve the right to hold back for now, until I can figure out my own plans of attack for my turbo 3.0L setup.
None of which I've read within this thread is a "great" solution for our wants and needs. At least none past getting our PCM's with the proper calibrated software/hardware setups or a stand-alone fuel/ignition computer controller. I just don't trust the negative effects that will occur with these methods of "fooling" our stock PCM.
I had once messed with the idea of using mechanical methods of fuel augmentation. But I noticed it would only get me a portion of what I really needed. I then thought I'd add a programable map sensor to the mix. I only needed fine tuning of the fuel injectors pulse width to compensate for the crude mechanical methods I was going to use. Then I realized that my setup also needed a source for controlling ignition advance while on boost. Here is yet another electronic component (or ignition control such as MSD or Crane Cam's Boost timing master). Now are you finally seeing what I am seeing? All these "Band-aide" solutions add up to cost you more than a "good" stand-alone system with proper sized fuel pump and injectors.
03-04-2008, 09:18 AM
#27
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Well said mike. I will say this though....alot of these piggybacks seem to be a little pricey for what megasquirt costs....although like you said the time and effort for megasquirt exceeds a piggyback greatly.
03-04-2008, 03:06 PM
#28
My Ride: 94 Spirit
But what is being talked about here? Fooling the computer....or modifying signals that come FROM the stock ECU to the coil/fuel injectors. I would rather do the later because it can actually work. People seem to be talking both ways, but fooling just doesnt work for our ECU as far as I am concerned. Way different then people who run MAS systems or have cars that have 2-3 bar map sensors from the factory.
03-04-2008, 03:46 PM
#30
Engine: 3.0 V6
I was looking at Emanage and honestly i couldnt even pick out what i would need in the jumble of junk there.
