03-20-2008, 10:48 AM
#17
Re: Melted coil power connector
My Ride: '88 Daytona w/t-tops
Engine: 1.65 TII-3 Cyl-lol
V=I*R. Voltage could stay the same if current is increasing and there is less resistance in the coil. You need bigger wires that can handle more current.
03-20-2008, 12:16 PM
#18
My Ride: 95 Caravan SE
I really appreciate you getting involved and helping Ed.  Just to be clear though. The harness wires, leading to the connector, are not melting. They aren't even heating up that I have noticed.
The female pin contacts inside the harness coil connector, that the male coil pins slide into, are what is heating up. Then they very slowly melt that plastic harness plug they are inside of.
(A)
|| <- the two male pins on the coil itself
(B)
UU < the two female harness plug pin contacts
So my theory is this.
The female pin contacts were a bit sloppy, leaving some airspace between them and the male coil pins, which allowed some arcing to take place and generate heat.
This heat generation, slowly increases over time, because carbon builds up at the arcing points and decreases current resistance. The lowered resistance then increases the arcing, that degraded the metal pin contact, part of which fell out of the connector upon my inspection of it..
Is any of that right? Or have I made some wrong assumptions here?
On Edit: ( Clarified the stuff in red, and added forgotten detail about part of the metal contact falling out)
Maybe I can compensate for that, by getting a new harness coil connector and bending the female pin contacts together a bit more, so they fit tighter on the male coil pins, and the arcing will not happen anymore?
Man I am way outa my league here.
Please help.
03-20-2008, 12:23 PM
#19
You are right about what the MSD 6A does Reaper, and MSD doesn't recommend upgrading the harness wires, or the connector itself, when installing their 6A CD unit.
On Edit: ( MSD does say you need a hotter coil with it though.)
Please, take a look at my last post, and tell me if you think my theory is right.
03-20-2008, 12:30 PM
#20
That sounds very plausible.
03-20-2008, 02:35 PM
#22
Well the the plug probably has the thinnest metal throughout the entire wiring system. If one spot is going to get hot because of too much current I would think that it would be there.
03-20-2008, 06:53 PM
#23
03-20-2008, 06:54 PM
#24
Kermit I guess so.
03-20-2008, 07:16 PM
#26
My Ride: 1990 Daytona
Engine: 3.0L V6
Do you see a carbon buildup paths from arcing? Usually the arcing (if bad enoug) can cause ozone which makes parts brittle with time, not so much to melt plastics. Since its not the wires, you could try to add some thin metal in the prongs to make a shim effect if you do see carbon arcing paths.
Another thing to try is to mount the coilpack somewhere away from the engine (firewall, pass side inner fender well), since it's mounted on the engine, once the engine has warmed could be just adding extra heat to a already hot coil.
03-20-2008, 08:14 PM
#27
Why is everyone trying to cover up the actual problem by trying to add more cooling?
EDIT: Is that the stock location of the coil??
03-20-2008, 09:30 PM
#28
True. But ham doesn't melt anymore than bread does. Now cheese. That melts.
03-20-2008, 09:43 PM
#29
Yeah, and you're not going to melt cheese on a icy hot pad either. The top of the engine isn't producing enough heat to melt the plastic. And if it was, cheese melts from the outside in, not the inside out.
...Unless you run wires through the cheese and run too much current through them. Check that first.
Reason: Makin' it make sense!!
03-20-2008, 10:01 PM
#30
Yes I do, a little on the end of the connector, and don't forget that piece of the female connector pin that fell out of the harness plug. The arc between the connectors, melted through the metal connector sheathes, and that caused the low level thermal degradation of the plastic plug.
I think I know what caused the harness plug connectors to get sloppy. I always pull the coil plug after I do an oil change and refill with oil, to turn it over until I get oil pressure without starting the engine, and I see-sawed the plug back and forth to disconnect it last time, because it was a fresh tight one.  Next time I will pull it straight out.
