OK then. A few posts back I said the following.
Originally Posted by me
IMO "a real vacuum in the crankcase" as you speak of, would resist piston upstroke, which would not be good for obvious reasons, .... including ..... the repetitive spikes in vacuum traction caused by piston upstroke, .... that could actually increase blow-by. The same could even adversely affect both ring and cylinder bore .... oil film distribution .... to decrease ring seal even as it also increases both ring and cylinder wear.
I believe that one important part of PCV, is the maintaining of proper crankcase gas pressure, and either too much, or too little like an actual vacuum, will cause all sorts of problems in addition to those I theorized above.
For example the constant thump thump thump of vacuum spikes, as the pistons move up and down, may even also trash engine seals over time. Our engines were not designed to deal with such an issue, and keeping the PCV system functionally as close to OE as possible is the best policy .... IMO. :)
Maybe I am wrong about this. Please consider the following though.
I can agree, that an actual small amount of crankcase vacuum, would promote ring seal on combustion down stroke.
There is however the same CC vacuum present, as another piston is heading back up on exhaust stroke with an exhaust valve wide open, and there and then cylinder gas pressure is not nearly as high, especially if you have a longer duration cam as some here have.
Here is an additional consideration I was thinking of.
If the same engine has poor ring seal, because the rings are coked or they were not fully embedded and the cylinder walls are glazed, which is why some here may be considering the vac pump Ed mentioned, then this 'elevated' pressure differential becomes a concern in the manner I refer to in my above post.
So we are also talking about 3Ls that either have a bit of age, with some wear and or accumulated carbon and varnish, or those with very poor ring seal for mechanical reasons. Many within either case, are also running oil that is way too thick, as a band aid, and I think that goo can be sucked out of the ring packs, because it really cannot penetrate worth beans and stick to them, on even a good day.
Just my less than expert opinion. :)
