Old 08-14-2008, 08:55 PM   #1
any one have pic?
Level 1 Supporter
of the 3.o dizzy cap at stock timming , a nice pic that shows the pointer at the front
mopar3.0 is offline
Old 08-14-2008, 09:40 PM   #2
Re: any one have pic?
TD Extreme User!
I think you will run into problems setting timing like that because they seem to be different on both my motors (because of tolerances).
Old 08-15-2008, 04:18 PM   #3
Level 1 Supporter
dont have much choise till i get a stock pulley
the car sems to be struggling some in the high rpm, well it pull good but just got more left, it could be runnign lean too i guess. i broke my wide band sensor welding on my headders
got to get at my mega squirt, need to rder a harness from dyi auto tune because everone is telling me my relay board is junk and a waste of time
mopar3.0 is offline
Old 08-15-2008, 04:45 PM   #4
TD Extreme User!
I can take a picture of my spirit's but it doesnt have a pully and I honestly dont know what the timing is at. I just have it set that it doesnt ping going up hills. My Duster has a normal pulley but ive never measured the timing. I just put it where it idles decently cause of the cams. I did turn it back a few degrees a month ago when I turned up the boost a little.
Old 08-15-2008, 08:21 PM   #5
Hybrid Booster
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
I just set mine by ear. I've done it often enough that I can just tell when she's right.
Avenger is offline
Old 08-17-2008, 10:50 AM   #6
Level 1 Supporter
can some one take me a pick to shut me up?
any one want a ms realy board?
mopar3.0 is offline
Old 08-17-2008, 08:46 PM   #7
TD Extreme User!
sorry I hadnt slept since thursday (8 hour nap after church today) working on my cars, having them break down and putting bansheenut's car back together.
Ill go take some pics to help you out.
edit, Ill try to do it when I wake up. which might be sorta late. My sleep schedule is all screwed up now thanks to working on broken cars.
Old 08-18-2008, 03:27 PM   #8
Level 1 Supporter
yea i have pulled a lot of late nights latley,
going be a late one this week to hopefully make my 3'' exhaust sound almost stock
mopar3.0 is offline
Old 08-18-2008, 09:46 PM   #9
TD Extreme User!
Try putting it there. After taking the pic I moved it back to line up the pink lines I made last winter because I want to throw as much advance at the car as possible. Im not going up any hills and I want mileage.
But i have no idea what the timing is set to in this picture. My duster has a timing wheel but it has no fuel/ignition with the new problem so I cant get better info then this :P
I can take a picture of the NBP that I got from m90daytona because he claims the timing marks he made actually work. The ones I made on my Spirit's pulley don't work and I haven't tried swapping them cause I ignore my Spirit at all opportunities.
Old 08-19-2008, 04:12 PM   #10
Level 1 Supporter
yea thats about were mine is. must be fule problem, wish my new wide band o2 would hurry up
mopar3.0 is offline
Old 08-20-2008, 12:27 AM   #11
TD Extreme User!
My guess is that is 14-15 degrees. You should not have problems around there. Widebands kick butt. My duster started again today so maybe this week i will check the timing.
Old 08-22-2008, 09:34 PM   #12
Hybrid Booster
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
Why do you need a relay board? The stock ASD setup works well as a "relay board" and looks factory.
87turbodance is offline
Page generated in 0.19383 seconds with 11 queries
