Old 10-24-2008, 08:51 PM   #1
Cool
Here is the work I have now. I will work on weight and measurements in the future. I can get more pictures of anything if requested.
Weights. I have pictures but I dont know when I will feel like posting them all.
PTU - 35 lb
driveshaft - 20 lb
Axle - 15 lb x2
Rear End - 57 lb
Coupler - 60 pounds
misc parts and bolts - 6 pounds
148 pounds minus coupler (probably 10 more pounds for lengthened driveshaft).
208 pounds with coupler.
Then add the weight of rear disc brake setup attacked to rear axle, or using your own axle. (not using crappy huge 8" wide minivan drums).
Copy of Post #81
Here are the pics from when I took the thing apart. Trying photobucket now and I love it. This would have taken an hour on imageshack.
63" wide at the rear end from the mating surface of each axle.
119" long from PTU shaft to center of rear end.
Old 10-24-2008, 09:08 PM   #2
Re: Chrysler AWD for us! (video and pics)
My Ride: 90 lebaron coupe
Engine: v6
so its out of a minivan? theres a couple in the local wrecking yard but i never thought anything of them
jatoboy is offline
Old 10-24-2008, 09:35 PM   #3
It is a bolton for a604/a413 transmissions. For 543/523/568 you have to drill and tap the case for the PTU adapter shown in picture #3.
And you have to swap ring gears and bolt it on the other side of the flange of the differential because the ring gear is located differently on the 4 speed auto.
Old 10-24-2008, 11:26 PM   #4
Junkyard Booster
My Ride: 86 GLHT
Engine: 2.2 turbo
Feedback: (7)
so this would work with a 413? i think i'm getting ideas..... :)
roachjuice is offline
Old 10-24-2008, 11:55 PM   #5
My Ride: 92 sundance duster
Engine: 3.0L 24v
huh, it looks like its more of a bolt up to the A543 than you think. the diff is in the same orientation, and the PTU adapter looks like the same bolt pattern as the shaft extension on the pass. side of my A543. this gives me ideas too.
How strong is the PTU? would it hold up to abuse?
Shadow24V is offline
Old 10-25-2008, 12:03 AM   #6
My Ride: 1987 Shelby CSX
Engine: Soon a 3.0L
I'm waiting for one of my father-in-laws awd caravans to kick the bucket (he has 2) so I can snatch up some parts
kreel is offline
Old 10-25-2008, 01:17 AM   #7
Some people seem to think its very strong. At least compared to some import AWD systems. Our transfer case is pretty dang big. It uses a hallow shaft so the passenger axle can go through the middle and engage the other side of the spider gears on the Diff. It might be possible to use an LSD diff in the front if you can get the splines for the PTU shaft cut into your LSD Diff.
I haven't compared the bolt pattern. Someone else said auto doesnt bolt to 5 speed. Either way, that is the easy part. The hard part is the rear end.
Old 10-25-2008, 10:29 AM   #8
Engine: 3.0L 24v
there an LSD option for the rear? and is that a Viscus center diff as well?
Old 10-25-2008, 11:46 AM   #9
The 2001 (or something like that) has a normal viscous coupler in the rear. This one is controllable with solenoids and crap.
You can use any rear end you want that has a 3.42 ratio if you want LSD, you just wont have the viscous coupler likely.
I havent decided what I will use in the rear yet.
Old 10-25-2008, 12:30 PM   #10
Engine: 3.0L 24v
i was thinking something like that, ditching the VCU and putting something with an LSD in the back in. that way, you could spin all 4 if you had the power :) hmmm, i wonder what as a 3.42 rear ratio that can do that...
Now, say it can couple to an A543, id need a 3.77 rear ratio then?
Old 10-25-2008, 05:17 PM   #11
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
I've been told that the quote-unquote later versions are strong, but the early versions tend to fail internally. No idea what the difference between them is, or when they changed it. But I have seen a lot of 3rd gen AWD vans that hit the junkyard with that PTU case pulled already.
Avenger is offline
Old 10-25-2008, 05:50 PM   #12
It might be the weird coupler they have in the back, they changed that to a viscous coupler in 2001ish.
Old 10-26-2008, 03:35 AM   #13
Administrator
bansheenut420's Avatar
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Images: 119
off topic sort of, but you said this was off a 3.3l van? Did you happen to notice if it had a 58mm tb on it?
And get busy on making the thing awd!
Cory Hedin
I have a running T3 car! Woot Stock head for now 12.3@111 low boost :evil:
-87' Daytona Shelby Z W/ T tops <----Now broken.... It never ends. :(
bansheenut420 is offline
Old 10-26-2008, 12:44 PM   #14
The Red Baron
Polygon's Avatar
My Ride: 1989 LeBaron GTC
Engine: Turbo II 2.2L/135ci
Images: 79
So, how long have you had this in the works man?!?!? This is awesome and I can't wait to see it action.
Clint: 1989 LeBaron GTC Turbo II - 1991 Dodge Stealth R/T TT
My CarDomain Garage
Polygon is offline
Old 10-26-2008, 12:47 PM   #15
Going Hybrid All Around
1983Rampage's Avatar
My Ride: 1989 Daytona ES
Engine: 2.5l T2
Feedback: (13)
Gaw Cory, have to go and ask off topic questions, gaw, those mods should come in and get things back onto track, LOL. I kinda was wondering the same thing when he said where it came from as well.
But looking at the setup, makes me kinda wonder if they "truely" got rid of the AWD setup that they had worked on for the TD's. But will this setup even work with the old TD's? Or were the splines on the shaft different? I think it would be kinda cool to do an AWD A555 Daytona with a 16V conversion on it. Kinda like the Daytona Project that was scrapped by Shelby and Lotus.
Which would you rather have, go fast goodies or shiny shoes?
Your feet may look good, but if your engine blows up, you ain't going anywhere.
1989 Dodge Daytona ES - T-top - 2.5l T2 with A555
1983 Dodge Rampage - 2.2l T2 with A525 (RIP)
1984 Dodge Rampage - 2.2l Carb with A525 (RIP)
1987 Dodge Shelby Charger GLHS #782 (RIP)
1987 Dodge Lancer ES - 2.2l T1 with A413 (RIP)
1983Rampage is offline
Page generated in 0.21951 seconds with 9 queries
