05-12-2009, 06:27 AM
Re: Stock 3.0 running 24psi boost
My Ride: '93 Dodge Shadow ES
Engine: 3.0 v6
Hey Brent,
The rings are initially "spring loaded" against the cylinder walls, light pressure. When combustion occurs, gas pressure adds to the ring pressure, making the seal. If the rings are overheated, they lose their original "spring load" & relax. When the cylinder fires, the gas pressure is equal, inside-outside of rings, & they won't seal.
The signs are burn marks down the side of the piston.
SpeedyEd
