06-26-2009, 06:39 AM
#25
Re: Megasquirt install
My Ride: 92 sundance duster
Engine: 3.0L 24v
you can use the CAS, but i never did figure out how to get the 24v dizzy to work right. Initially it was because there was an NPN transistor in the coil ground circuit where you had to SUPPLY voltage to ground the coil. After i figured that out, the actual ignition timing was all over the place for no apparent reason so i gave up and went EDIS-6 with some GM coilpacks and a 36-1 wheel welded onto the crank pulley. The 24v SOHC dizzy does computer controlled timing somehow so its not a "traditional" dizzy like the 12v
What trim is the stealth? base, SL or VR4? the VR4 has a DIS system already, and im not sure about the N/A DOHC, but the base motor is essentially the same as the 12v we have, dizzy, HEP etc
