Old 06-17-2009, 02:50 AM   #46
Re: O2 sensor MADNESS!
My Ride: 93 plymoth sundance
Engine: 3.0 6g72
where is the ground you think you fixed i found 2 on both my 93 daytona and 93 duster to be in the same location 1 by the pass. motor mount to the body right there and one going fron the fire wall to the alt.
be thankfull you didn't find my problem there was a fuseable link so badly corroded the it blew and then it blows the fuse i put in its place pulled some of the protecting cover back of the wire harness and find the ins. is falling off the wire
new wire harnees or if i had the money i would get the megasqurit to put in its place along with a painless style wiring harness for the body. i have put the body harness in before that will be easy enough just need $$$$$$
paduster is offline
Old 06-17-2009, 04:54 AM   #47
Yep. The one right from the motor mount, to the body, is the one I restored. My fusible links are all OK, as is my engine harness. Thanks for the warning. :) Sorry about your wire situation. Lucky you found it now though. Get it fixed while you can. The economy is going to flatline pretty soon, and then we will be very lucky to even have gas.
I would like to replace all of the engine compartment wiring though. Does painless, sell them ready made, for our cars? I would also like to replace my fusible links with breakers. I have seen that done as an upgrade.
Money however is an issue here also.
lookin is online now
Old 06-17-2009, 09:09 AM   #48
Engine: 3.0 6g72
no nothin for our cars i used a geniric body harness to do the job last.
paduster is offline
Old 06-17-2009, 06:04 PM   #49
Wow, paduster, I am impressed. It would take me, a lot of study time, before I felt up to such a task.
We finally got the O2 warmer circuit repaired. Works great too. :)
We went for a nice long drive and gave the van a workout.
Old 06-17-2009, 06:07 PM   #50
Thank you to all who helped. :)
Old 06-17-2009, 08:38 PM   #51
Engine: 3.0 6g72
no problem i did go to school to build cars at a school in ohio i have done allot before but none on the turbo dodges
paduster is offline
Page generated in 0.14698 seconds with 9 queries
