12-10-2012, 11:24 AM
#20
Re: ok i got a problem
- OFFICIAL GEARHEAD -
My Ride: 94 Dodge Shadow
Engine: 3.0L 24v
My comment was based on some components not soldered to the board. Some people don't assemble all the possible circuits on the MS if they aren't needed.
IIRC I think he put the igniters in the GM module and ran it direct from the MS. If that is the case, you can probably leave the GM module part out and use the Kia coils directly if they have built-in ignitors as knightmoves indicates.
stock fuel system can probably hold up to an N/A application just fine. The stock FPR on the motor should be OK as well, provided its a return style, not a returnless like some newer cars
