plenum SWAP (NOT flip) - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > Mitsubishi V6 engines
Mitsubishi V6 engines Discussion area for the 3.0 turbo and non-turbo
Old 12-13-2012, 04:12 PM   #1
My Ride: plmouth duster
ub3r l33t dud3 is keeping the peace
I would like to swap my plenum for one that dosent have an egr, because the egr plenum has an extra protrusion that sticks down farther than the non egr does. My egr is already deleted, however the vacuum routing is different on the two plenums...
Here is a picture of my egr plenum compared to the non egr plenum, the vacuum fitting on the top of the egr is what is confusing me, i cant figure out what it is used for.
It appears to just "t" into the vacuum line that goes to the charcoal canister. (ignore the clear vacuum line and the loop that it connects to, that is for my vacuum gauge)
Also there is an extra vacuum line off the back of the non egr plenum that appears to be used by the emissions system, i think it is just a different design than my emissions system.
They are both the same year, however my car is an auto.
ub3r l33t dud3 is offline
Old 12-13-2012, 04:44 PM   #2
Re: plenum SWAP (NOT flip)
Moderator
knightmoves's Avatar
My Ride: 87 daytona T top
Engine: 3.0 V6
Feedback: (15)
Images: 37
knightmoves is keeping the peace
the 2 vac lines on the third pic are for the MAP sensor and the fuel pressure reg. the others are just fine. just swap the non EGR over and run the lines the same as before except for the line going to the EGR.
knightmoves is offline
Old 12-13-2012, 05:31 PM   #3
sorry i should have put this lol, the first and third pick are of my car, the second and forth are of the non egr car.
i mostly need to know what that vacuum line off the top of the throttle body is for, i don't really understand why it would be there on the manual and not the auto, i have seen it on many pics here and it was on the original intake that came with the engine that i put in this car, i put my egr intake and exhaust manifolds on this engine when i put it in.
Old 12-13-2012, 05:34 PM   #4
---SITE GUIDES---
6g72 acclaim's Avatar
My Ride: 95 acclaim, 06 strat
Engine: 6g72 and 2.7
6g72 acclaim is keeping the peace
Did it on mine. Like knightmoves said just run everything back where it came from, may require swapping the vacuum hookup on the back.
I will also suggest leaving the egr solenoid plugged in unless you don't mind a cel all the time.
6g72 acclaim is offline
Old 12-13-2012, 05:47 PM   #5
all of the egr system is removed, and no check engine light, i removed the system when the car was getting 8mpg, turns out the whole system still worked great. and ok i will just swap the the intakes and hook the extra line up as it was on the original car.
Old 12-13-2012, 05:50 PM   #6
---SITE GUIDES---
Interesting, mine popped a light as soon as I took it off
Old 12-13-2012, 06:58 PM   #7
Authorized TD Vendor
c2xejk's Avatar
My Ride: Spirit R/T
Engine: 3L V6
c2xejk is keeping the peace
If you want to delete and seal the EGR port on your existing manifold, I can do that for an extra $10 while I am porting the manifold.
Ed Kelly
Kelly-Mulhern Performance
c2xejk is offline
Old 12-13-2012, 08:50 PM   #8
Ed Kelly
ok cool. i just realized that you are in the next state down... i thought you where in Calli or something lol. i might have to come see your car next time i go to Wisconsin if i don't take the fairy across.
and 6g72 acclaim, did you take off the egr valve and block it off?or just disconnect it? we have a stack of block off plates for the egr valves, we block them off on almost all of our td period dodges(cause they all go bad lol).
Old 12-13-2012, 09:01 PM   #9
Garrett Booster
My Ride: 93 duster
Engine: 3.0 181
nilo420 is keeping the peace
I have a non egr plenum and the 2 on my plenum are capped off.
nilo420 is offline
Old 12-15-2012, 12:21 PM   #10
---SITE GUIDES---
I completely removed it. I capped the manifold and swapped to a non egr plenum.
Once I snagged a solenoid and plugged it in the cel went away???
Old 12-16-2012, 03:07 AM   #11
Garrett Booster
My Ride: 1992 lebaron vert
Engine: 3.0L SOHC Vin 3
3.0LeBaron is keeping the peace
same on both the engines i had a 89 and a 92
3.0LeBaron is offline
