New to the 3.0 world and my plans - Page 3 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > Mitsubishi V6 engines
Mitsubishi V6 engines Discussion area for the 3.0 turbo and non-turbo
Old 02-25-2013, 12:39 PM   #31
Re: New to the 3.0 world and my plans
- OFFICIAL GEARHEAD -
My Ride: 94 Dodge Shadow
Engine: 3.0L 24v
Shadow24V is keeping the peace
Any reason to keep the Automatic? 5Speed swaps are fairly easy and common...
Shadow24V is offline
Old 02-25-2013, 12:53 PM   #32
My Ride: Modded 94 spirit 3.0
Army4life73 is keeping the peace
Can't find a donor car everyone scrapped anything that didn't run this past summer
Army4life73 is offline
Old 02-25-2013, 02:59 PM   #33
Engine: 3.0L 24v
Bummer. You might be able to find someone on the forum with a donor car/parts. IMHO a 5-speed really wakes the 12v 3.0 up...
Old 02-25-2013, 03:15 PM   #34
6g72 builder
knightmoves's Avatar
My Ride: 87 daytona T top
Engine: 3.0 V6
Feedback: (15)
Images: 37
knightmoves is keeping the peace
I agree with you on that!!! I have driven all three! the 5 speed,604,and 670 the 5 speed really drives 1000 times better than the autos! faster too!!!!
knightmoves is online now
Old 02-25-2013, 09:45 PM   #35
Authorized TD Vendor
c2xejk's Avatar
My Ride: Spirit R/T
Engine: 3L V6
c2xejk is keeping the peace
While I agree with that, I must say I have been toying putting a built AT behind my turbo 24v 3.5L... Probably not this year, but the thought is there...
Ed Kelly - Kelly-Mulhern Performance
c2xejk is offline
Old 02-26-2013, 05:39 AM   #36
Engine: 3.0L 24v
A built AT can be a good addition to a higher power motor. I know NMW2006 was building the hydraulic trans (don't remember if it was the 3-speed or 4-speed) for his 3.0 Turbo Neon build. I just like to row my own :)
Old 02-26-2013, 06:47 AM   #37
I will probably start with new trans and motor mounts and a shift kit. I have to get a new axle this week my pass side one is goin out so I gotta get that fixed before I put anymore power to it. Then go into gettin intake and exhaust.
Old 02-26-2013, 08:43 AM   #38
Engine: 3.0L 24v
In my past experience, be wary of the "new" axles from the parts store. Granetd I broke both at the drag strip launching HARD on slicks, but if there is a good driveshaft shop near you, you may want to get your OEM axle rebuilt. The Saginaw thick-walled tube passenger axle I believe to be much stronger than the "new" chinese-made solid-shaft axles.
But that's my opinion (I had over 100 drag passes and 250K miles on the original axles, but snapped the "new" ones first two times out to the strip. I am back running OEM axles)
[SIGPIC]http://i36.photobucket.com/albums/e9/bubblebob88/motm3.jpg[/SIGPIC]
Old 02-26-2013, 11:47 AM   #39
There not new new ones they are the reman ones
Old 03-14-2013, 04:44 PM   #40
---SITE GUIDES---
6g72 acclaim's Avatar
My Ride: 95 acclaim, 06 strat
Engine: 6g72 and 2.7
6g72 acclaim is keeping the peace
I'm assuming being a 94 your car is the 670 3-speed auto. If that's the case the valve body can be modded for better shifts. Mine was built with a 2500 stall, it would launch hard and chirp 2nd on the shift, but it's on it's way out now cause they messed it up.
The 3.0 really comes alive with more airflow. Stock they're pretty much done at 4k.
I have intake, 52 TB, ported plenum, 1" spacers, mildly ported heads, diamante cams, and full 3" exhaust. I have strong pull from 3k to the rev limit. Just intake, TB, and plenum make a big difference though.
95 Acclaim
3.0: 3" intake, 52 mm tb, P/P plenum, 1" spacers, 3" exhaust. Ported heads, new fuel system.
Built 3spd auto.
Repainting (Plum Crazy Purple), adding RT GFX.
90 Spirit ES 3.0 SOLD!
06 Stratus
2.7: Weapon-R intake, 3-1 Headers, 2.5" exhaust, dynotuned.
B&G coils, KYB struts, CD/slotted rotors, EBC pads, Fuzion tires, Carbon hood, Projector Heads, LED tails, Matched wheels.
6g72 acclaim is offline
Old 03-14-2013, 08:29 PM   #41
Ya I think I'm gonna start out small go with porting my intake and 52mm TB and exhaust. Is it better to stick with OEM dist and rotor or is there some sort of great aftermarket ones that will make a good difference. Also what about my coil pack?
Old 03-15-2013, 08:35 PM   #42
I have a problem that I can't figure out I think it might bet egr valve but not sure. Well Thursday it ran fine no problems today I start it up to go to work and its idling rough. It's real rough when I put It in reverse and mildly rough in drive. It sputters and acts like its missing real bad when I accelerate up to 3k rpms then it smooths out. I replaced my cap,rotor,plugs , wires and fuel pump and map sensor and still doin it no difference in it. Any help would be awesome. Thanks everyone
Old 03-16-2013, 01:01 AM   #43
Garrett Booster
My Ride: 93 duster
Engine: 3.0 181
nilo420 is keeping the peace
try pulling the codes off the ecu by on off on off on with the ignition switch count the flashes of the check engine light (*flash* pause *flash* flash* would be 12) then check this out 1980s Chrysler, Plymouth, and Dodge computer fault codes
nilo420 is offline
Old 03-16-2013, 01:15 AM   #44
It brings up 32 so it is my setting with my egr valve. I will have to tear it apart Tomorrow and check it out
Old 03-23-2013, 11:40 AM   #45
---SITE GUIDES---
Bypass it, or get rid of it completely. That's what I did. My car was giving me the same crap. I got an older non-egr plenum and ported it, then capped the exhaust.
Tags
3.0, alternator, battery, throttle body
