New to the 3.0 world and my plans - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > Mitsubishi V6 engines
Mitsubishi V6 engines Discussion area for the 3.0 turbo and non-turbo
Old 02-22-2013, 02:11 PM   #1
My Ride: Modded 94 spirit 3.0
Army4life73 is keeping the peace
Hello I am new to this so any help would be greatly appreciated. I'm gettin out of dsm's. well to start off my car is a 94 dodge spirit 3.0 v6. Completely stock at the moment. My plans for it are for a 52mm Tb,underdrive pulleys, porting my manifold, gettin better wires , full exhaust and CAI. As far as the intake I'm just getting hard piping from the parts store and a cone K&N filter. The exhaust I want to run 2.5 in piping all the way back with no cat and a single in and dual out muffler. I already have the 52mm Tb just have to port my mani first. I thought about underdrive pulleys but I herd as far as if you have a stereo on Ur car it pulls the alt. bad. But as far as anything else others have done and seen results from I would try it. It would all have to be easyish stuff. I mean I could do a full build but this is my dd at the time so I'm limited on my time able to have it torn apart. Thanks
Army4life73 is offline
Old 02-22-2013, 02:30 PM   #2
Re: New to the 3.0 world and my plans
6g72 builder
knightmoves's Avatar
My Ride: 87 daytona T top
Engine: 3.0 V6
Feedback: (15)
Images: 37
knightmoves is keeping the peace
OK, cool!!!! to address your post in the other thread. to remove the dizzy and go with coil packs you'll have to go with a stand alone computer. Megasquirt is the most popular around here. they are a lot cheaper than other on the market and DIY auto tune is one of our venders. a number of us have ditched the dizzy so getting help with it will be easy! here is a link to the DIY site!!
MegaSquirt | Engine Management System | Electronic Fuel Injection - DIYAutoTune.com
knightmoves is offline
Old 02-22-2013, 05:16 PM   #3
Alright what about the exhaust part. I would like it to get breathing better before I start doing engine management stuff I'm wanting to do a dual exit muffler but I don't want it to obnoxious like flow master 40 series I just want a nice deep tone
Old 02-22-2013, 05:51 PM   #4
6g72 builder
Engine: 3.0 V6
Feedback: (15)
Images: 37
I got this 3 inch exhaust and bought the 3 inch high flow cat too!!
Forward Motion, Inc. 2007 Catalog
Old 02-22-2013, 06:00 PM   #5
I was just gonna delete my cat cause they don't so emissions where I live
Old 02-22-2013, 06:02 PM   #6
6g72 builder
Engine: 3.0 V6
Feedback: (15)
Images: 37
the kit comes with a pipe to delete it if you like.
Old 02-22-2013, 06:08 PM   #7
Where would I order a kit from
Old 02-22-2013, 06:10 PM   #8
6g72 builder
Engine: 3.0 V6
Feedback: (15)
Images: 37
from the link I posted ! forward motion. Mike is the owner and he is a great guy to deal with!
Old 02-22-2013, 06:18 PM   #9
Only place I know that sells performance parts for my car is forward motion
Old 02-22-2013, 06:30 PM   #10
Ok didn't mean to put that last one after you replied but is there anyone who makes a Exhaust manifold cause that is one thing I have never found only for the 4cyl turbo version
Old 02-22-2013, 06:41 PM   #11
6g72 builder
Engine: 3.0 V6
Feedback: (15)
Images: 37
we have a vendor here that makes turbo headers. and you might get him to build N/A headers!!! KMperformance.com!!! Ed kelly is one of the guys who post here often!!! here is his profile page. http://www.turbododge.com/forums/4089-c2xejk.html
Old 02-22-2013, 06:46 PM   #12
Ok thank you I will see what I can do with gettin it to breath better for now.
Old 02-23-2013, 08:37 AM   #13
Authorized TD Vendor
c2xejk's Avatar
My Ride: Spirit R/T
Engine: 3L V6
c2xejk is keeping the peace
I have run a UDP before, the biggest problem will be at idle. If it gets too low the alternator may not be able to keep up. So voltage will drop from ~14v to 13v or 12v.
I don't run a stereo with big amps so I can't personally speak to if that is enough draw.
Bottom line for a normally-aspirated car, if you are looking for a little more power, it can gain you 4whp (off peak hp.) It is a noticeable gain...
For a turbo car, I would rather bump boost up a little more...
Ed Kelly
Kelly-Mulhern Performance
Ed Kelly
3L V6 Guru and all around FWD Mopar fanatic
'91 Dodge Spirit R/T turbocharged 3L V6, exhaust turbo header, ported intake, stage 2 ported heads
'87 Dodge Shadow turbocharged 3.5L 24-valve 6g74 .
c2xejk is offline
Old 02-23-2013, 09:29 AM   #14
Alright I don't have any thing rediculous just a 400watt amp and a small sub. And also my goal is to try to get clost or at 200 whp with out going into the motor if that is possible.
Old 02-23-2013, 12:16 PM   #15
6g72 builder
Engine: 3.0 V6
Feedback: (15)
Images: 37
ok, here is the path i would take. first you wont have to go into the lower end of the motor BUT,it would help if you did. First,get a set of stage 2 ported heads from KM performance,2nd a set of regrind cams from some one like Crower, 3rd megasquirt. i would get the MS3 and use the ignition from like a dodge 3.3/3.8 or like I did an ignition from a 3000gt/stealth. another ignition is the ford edis. next get a set of headers made for your car and run 3 inch exhaust to the rear. install a walboro 255 fuel pump and a new adjustable fuel pressure regulator. use jeep 4.0 spark plugs. if you want to really help the motor replace the stock pistons for a set of 10:1 pistons from a 95 Mitsubishi Diamante rock auto sells them new! stick with the factory crank pulley, you'll need to to install the crank trigger wheel for the distributorless ignition. Also your intake. get a lower from a montairo and build a custom intake with a 90mm throttle body from a Q45! it is a great throttle body and will give you great throttle response with out being hard to drive! if you want to go cheaper keep the distributor and not use the megasquirt and just go with Emanage blue. it will increase your fuel with out effecting the ignition.
"Better to be silent and thought a fool, than to open your mouth and remove all doubt!"
Tags
3.0, alternator, battery, throttle body
