Cold air intake bypassing ECU, issues? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo specific > Mitsubishi V6 engines
Mitsubishi V6 engines Discussion area for the 3.0 turbo and non-turbo
Old 03-06-2013, 08:50 PM   #1
My Ride: '93 Dodge Spirit
Engine: 3.0L V6
TheLaw is keeping the peace
When I did my intake, I noticed that the factory air intake passes over the ECU module, and I was under the impression it was like that to help it stay cool. But with my current intake, I left the ECU part untouched. It's still in the box with the air openings (though I hacksawed off one end where it stuck out.)
Is there any long-term or short-term reliability issues with this?
I know most automotive electronic parts are usually rated for temperatures in excess of 200*F, but I'm not too sure with a 20 year old car if this will cause issues.
Ideas?
TheLaw is offline
Old 03-06-2013, 09:03 PM   #2
Re: Cold air intake bypassing ECU, issues?
Garrett Booster
My Ride: 93 duster
Engine: 3.0 181
nilo420 is keeping the peace
don't know but i routed my cold air into the ecu. seems to work well.
nilo420 is offline
Old 03-06-2013, 09:49 PM   #3
Level 1 Supporter
DPE91's Avatar
My Ride: 93 Daytona Base
Engine: 2.5L TBI
DPE91 is keeping the peace
I did similar on my P-body but I did put a small computer fan on mine.
DPE91 is offline
Old 03-06-2013, 10:22 PM   #4
TD Hardcore User!
My Ride: Daytonas
Feedback: (11)
ChargedDust is keeping the peace
Split the case and clean off all the heat sinks real good, then go with the computer fan.
ChargedDust is offline
Old 03-07-2013, 12:13 AM   #5
Should Buy Another E30
TurboDodge's Avatar
My Ride: Daytona Shelby VNT
Feedback: (41)
TurboDodge is keeping the peace
It really depends on the climate you live in and the average ambient air temp. I live in the PACNW, and it really is only hot here for two months a year, if your lucky. And when I say "hot" I mean 85. I have owned so many TD's over the years that had aftermarket intakes w/ out ducting to the ECU and I have never had an ECU failure due to it. HOWEVER, if I lived in an area that consistently had high ambient air temps, ESPECIALLY in areas with summer temps soaring in the 100's, I would think about keeping the "air draw" over the ECU board, or install a cooling fan as previously described. If you live in Alaska, your underhood temps are freeeeeezing, those guys don't worry so much about electronics overheating. But, after all this being said, the HP gains of an aftermarket intake are nil. So, if you are really worried about ECU failure due to overheating, keep it stock.
----T28 VNT, FMIC, RFL BOV, Dynomax Super Turbo Cat-Back Exhaust System----
TurboDodge is offline
Old 03-07-2013, 09:35 AM   #6
My Ride: plmouth duster
ub3r l33t dud3 is keeping the peace
i have been driving mine for two years with out my intake routed through the ecu, havent had a problem since. however i live in Michigan.
ub3r l33t dud3 is offline
Old 03-07-2013, 11:56 AM   #7
CBMDennis
CBMDennis's Avatar
My Ride: 1988 Labaron Convert
Engine: Turbo 1 2.2 liter
Feedback: (28)
CBMDennis is keeping our cars running
Did you still have the scoop forcing air into the ecu?
CBMDennis is online now
Old 03-07-2013, 03:53 PM   #8
---SITE GUIDES---
6g72 acclaim's Avatar
My Ride: 95 acclaim, 06 strat
Engine: 6g72 and 2.7
6g72 acclaim is keeping the peace
I've been running mine for 2+yrs without the intake hooked to it with no issues. I still have the factory scoop at the front of it. The temps here range from below freezing to 100+ over the course of the year.
If you are really worried hook a fan up to it.
6g72 acclaim is offline
Old 03-07-2013, 05:57 PM   #9
Level 1 Supporter
DPE91's Avatar
Engine: 2.5L TBI
My P-body didn't have the scoop thing when i bought, and the only reason i added a fan was to be safe because it does get into the 100's sometimes where i live in NC.
DPE91 is offline
