Looking at buying a 3 bar map sensor and pigtail, I see some people use the msd ones and others use gm map sensors. I've also found them on ebay from 25-50 bucks new. anyone have any recomendations for a 3 bar map sensor or are they all about the same, thanks Brandon.
I'd go with the one FWDP sells, that way you know it's compatible with our stuff.
Don't forget, you need to have a 3 bar tune to go with the 3 bar map. If not, it will never run right. A 3 bar map puts out the same voltage range as a standard map, it's just re-scaled in the ECU so it reads correctly.
yeah I plan on doing the 3 bar map, calibration, fuel pump, adjustable fuel pressure regulator and +40's, just want to start gathering the parts. just curious what map sensors others are running.
Related Threads
Turbo Dodge Forums
2.4M posts
56.1K members
Since 2000
