I got a 83 Rampage AT. The power steering rack is shot. I would like to change to a manual rack. Will it bolt right on? I heard the splines on the column shaft might be different. Any info would be great. Thanks.
you'll need to change the u-joint / swevel thingy on the end of the shaft , not the entire collum
I think by mount bushing , he means the rubbers in the straps that hold the rack to the crossmember
I did the swap , manual to power - I think one of the straps and the rubber in it were different
try to get the mounting straps & rubbers and the swevel / u joint with the rack if it's comming from something that's still together with all it's related parts
I can tell you, doing it in a K body isn't fun either. You'll definitely want a helper.
The U-joint on the end of the steering shaft is held in by a roll pin. It is also pressed and/or seized on the end of the shaft. Not sure which, I just know it was a pain to remove it. Might need to apply liberal amounts of heat and wookie to get it off.
Oh if you're getting a new rack it doesn't matter. On a used rack the plastic bushings inside the rack on both ends tend to fail and you have to make new ones from brass or aluminium or whatever. Good luck!
Related Threads
Turbo Dodge Forums
2.4M posts
56.1K members
Since 2000
