Is Factory Cruise Control On 87 T2 Shelby Daytona Possible? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 28 Old 01-14-2017, 06:39 PM Thread Starter
- OFFICIAL GEARHEAD -
ILIKESHELBYS's Avatar
My Ride: SC/GLHS(2)/CSX
OK, real quick and short, I have two 86 Turbo Z's that were born a CS T1 cars. I am almost finished upgrading them to T2 specs, one is using the GLHS style Logic Module the other with an 87 Shelby Z logic module. Everything is going along just fine but the cruise control servo that is under the stock battery tray has to be moved apparently because of the intercooler's lower hose inlet location No big deal... But the cruise control servo cable end that attaches to the throttle body is way different on the T1 and is not going to work on the T2 style throttle body cable cam. I'm talking about the black plastic cam that moves the throttle body butterfly open/closed and that the throttle cable and speed control cables attach to.
So I looked in the Chrysler 87 parts book, and they don't list a speed control servo for the T2/Shelby cars with intercooler, only T1 car's without the intercooler and of course they have the same style cable as the 86 T1.
Is there such a thing as dealer installed cruise control in the 87 Shelby Z Daytona?
BTW, the 86 style cruise control is the type that takes a cable up from the transmission speed sensor to the speed control servo to get a speed signal, and it has a vacuum line attached to the brake booster to get the needed vacuum to run the servo and pull the cable as needed.
I'm thinking I need maybe just the right type of cable to fit the T2 style throttle body cable cam, or maybe the late T1 style throttle body which is I think just about the same.
So how is it we accomplish cruise control on a T2 Daytona...gen 1 Daytona that is?
Boost on...
Steven Seale
QUICK-FIT SHIFT RODS★ ~ ★A525/A555 CONVERSION BRACKET
QUICK-SHIFTER ★ ~ ★REBUILT TRANSMISSIONS★ ~ ★PT LIFTERS AND SHIMS
PROUD TO BE AN ACTIVE MEMBER OF THE TURBO DODGE ENTHUSIAST COMMUNITY
ILIKESHELBYS is offline
post #2 of 28 Old 01-14-2017, 09:58 PM
Super Moderator
Dr. Johny Dodge's Avatar
Re: Is Factory Cruise Control On 87 T2 Shelby Daytona Possible?
you do this by getting your hands on a TII cruise unit
Yes they really do exist .. 87,88 and 89
Yes the cable will be the correct one and I think the piece that bolts to the battery bracket may be unique in it's own mounting bracket
BUT .. hard as nails to find- rare like an innocent hooker
Heh heh..... what's it worth to ya ?
Yes , I do just happen to have one left from my blue 86 TZ TII conversion
If WAS in my car but I never used it with my MP smec conversion
Dr. Johny Dodge is offline
post #3 of 28 Old 01-15-2017, 08:59 AM
Level 3 Supporter
4Daytonas's Avatar
My Ride: 84 Turbo Z, 91 Shelb
Engine: 2.2-2.5
I did the same thing. My 85 Laser was converted to T2 status and I just made the throttle linkage by grafting the 85 to the 88 TB and used the 85 cables.. I made a mount to move the servo a little and I DID have to use a Masi lower hose to clear everything. 85(and 86) cruise is not controlled by the computer. I have a few pix but they are too big to post here. PM me an email addy and I'll get you the pix.
4Daytonas is offline
post #4 of 28 Old 01-15-2017, 12:23 PM
Hybrid Booster
As mentioned, 1987 T-II and GLHS cars diddn't have cruise available other than dealer or aftermarket.
I added 1988 cruise to my 1986 Omni when I converted to SMEC/Super 60 way back.
I have a box of servos collected over the years and possibly a Daytona servo strut mount bracket.
I had my SMEC tuned to allow approx 120 MPH on cruise.
I'm curious how the earlier units limited cruise top speed .
Thanks
Randy
Glhs60 is offline
post #5 of 28 Old 01-15-2017, 12:47 PM Thread Starter
Hey Doc Dodge, I knew somebody out here would have attempted something like this, I'm interested of course but wanted to ask a few questions about actually getting it working, maybe you remember what you had to go through to get it actually working.
From what I know the 85-86 cruise is not computer controlled but the 87 is from what I hear and read. Since one of the turbo Zs I have is using the GLHS LM I don't know if an 87 cruise will work on that car. On the other hand, the other turbo Z will have an 87 Shelby Z LM installed. Do you remember what was required electrically to get the 87+ style cruise to work in an earlier car. Since you were an SMEC car it would be different for sure but I am just wondering what wiring is required. Thanks buddy for anything you have to offer.
Boost on...
Steven Seale
post #6 of 28 Old 01-15-2017, 12:54 PM Thread Starter
I'm scratching my head over how the 87 Shelby Z logic module controls the cruise control...and I don't currently have any wiring diagrams for the 87 cruise control system in a G body. But one of the 86 CS cars being converted to T2 will have the 87 logic module.
...and now that you mention it, I do now recall seeing curise control servos mounted on the strut tower, those servo were a LOT smaller than the 86 style which is quite large.
post #7 of 28 Old 01-15-2017, 02:10 PM
Hybrid Booster
I mounted my cruise servo rather crudely to a strut bolt but kept searching for a cleaner installation.
With an intercooled L body there is no room for a battery box bracket like 88-89 ?? Daytona's used but I noticed later models mounted it to the strut tower.
Unfortunately there isn't enough room in an L body to use that bracket.
I have noticed many cars have the dimples in the strut tower for the bracket so I'm guessing it was planned to be used before it was.
I'm assuming you're going for the factory 88-89 look with the battery box mount, but those brackets can be very hard to locate.
I haven't even looked in my cruise box for years but know for sure I don't have the battery box bracket as Todd was looking for one a while back.
From memory he posted a picture of that style when he was looking.
Thanks
Randy
86 GLH S60
86 GLHS 373
89 Turbo Minivan
83 Rampage Turbo
Glhs60 is offline
post #8 of 28 Old 01-15-2017, 02:15 PM
Hybrid Booster
I believe these are Todds pics of the T-II cruise bracket.
Also I think 1989-90 VNT had this one.
Thanks
Randy
Name:	T-II CRUISE BRACKET A.jpg
ID:	217457   Click image for larger version
Name:	T-II CRUISE BRACKET.jpg
Glhs60 is offline
post #9 of 28 Old 01-15-2017, 02:19 PM
Hybrid Booster
Strut tower cruise servo mount.
Thanks
Randy
Glhs60 is offline
post #10 of 28 Old 01-15-2017, 05:30 PM Thread Starter
Thanks
Randy
Yes, I have seen a few of those style in the yards...not as commonly this year as last. So that would be the computer controlled version I assume, could be made to work on the 87 logic module I would think. I did find a 93 Voyager in the yard today, the servo looks the same, bracket different but that's not important. I noticed it has 4 wire connector on it. I'm totally guessing here but I don't have an 87 shop manual with cruise control wiring schematic.
I did some advance searches and found these diagrams...
I believe this is the generic wiring for cruise control 86 style:
..and this seems to be the later cruise control wiring for 87 style:
ID:	217489   Click image for larger version
Boost on...
Steven Seale
post #11 of 28 Old 01-15-2017, 05:36 PM Thread Starter
I grabbed the cruise control cable from the 93 Voyager today. It has the correct T2 style connector and end on it that I would need to use the standard T2 style throttle/cruise control cable bracket on the TB w/o any modifications, no fabrication. I don't know yet if its a good length yet. But if I can locate the appropriate cable to fit the 86 servo and that has the needed T2 style end on the TB side, I can avoid any wiring issues completely. I would then just need a suitable mounting system for the servo since the factory bracket just isn't going to work because of the lower intercooler hose.
ID:	217505   Click image for larger version
Boost on...
Steven Seale
post #12 of 28 Old 01-15-2017, 05:38 PM
Level 4 Supporter
87 shelby lancer auto trans cal will run cruise control.
ajakeski is offline
post #13 of 28 Old 01-15-2017, 06:13 PM Thread Starter
Thanks
Randy
Yes, here is a different shot of that bracket installed. 90 VNT car pictured...
Name:	90 VNT style cruise bracket.jpg
post #14 of 28 Old 01-20-2017, 04:30 PM
Hybrid Booster
I posted over on T-M and Gary figures the 1987 T-II LM would work.
Thanks
Randy
""Just try it.
I think it was just a packaging issue in 87 II.
Lots of TI boards came populated with TII hardware, I'm sure the "TII boards" had cruise control SMC on board.
Glhs60 is offline
post #15 of 28 Old 01-20-2017, 06:41 PM Thread Starter
Yes, I do have a T2 LM for that car's conversion. If I could make or find the needed bracket, the decision would be easier. I can give the Voyager cable a try on the car with the GLHS LM, that car is going to need some sort of custom mounting. The owner is very "must look stock" oriented. Having the pictures that have been contributed to the post has been a huge help BTW!
Thanks
Randy
""Just try it.
Human Verification
