Weird Electrical / RPM issue... - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
 1Likes
post #1 of 29 Old 02-14-2017, 05:59 PM Thread Starter
My Ride: 92 Spirit N/A
Engine: 2.2 MPFI
Ok so old ladies car, '93 Spirit 2.5 auto flex fuel. When you turn on headlights or blower motor engine bogs for just a second, when cooling fan turns on car bogs down BIG TIME and once in a while RPMs won't pick back up till fan turns off?.. At first I instantly assumed bad ground! Being that the car has a new battery and alternator. So I went ahead and ran "the big 4" something us 80's-90's guys would do when hooking up a boom box car stereo, you run all 2ga or bigger power wire from the battery to the alternator, a ground to the body of alternator, and body & engine grounds to battery. This did not fix the issue :( The ONLY other electrical issue this car has is randomly a while back the dome light stopped working, and after testing it, it's because it lost its ground... can't turn it on with headlight switch nor opening any door, and if I just grounded it of course it would stay on all the time. I have no idea if these 2 issues coincide or not but EVERYTHING else about the car is absolutely perfect. Thanks for any help guys, cuz I am stumped!
I'd like to add when car surges or bogs down, doesn't seem to dim lights or affect anything but the engine speed... and once in a while when starting the car the air bag light will come on, and sometimes stay on while driving... again thank you for any help or suggestions!
MarkassBauer is offline
post #2 of 29 Old 02-14-2017, 06:16 PM
Just A Guy
NAJ's Avatar
Re: Weird Electrical / RPM issue...
When the car "bogs for just a second" what is battery voltage reading at the battery?
post #3 of 29 Old 02-14-2017, 07:19 PM Thread Starter
Engine: 2.2 MPFI
Battery stays up at around 14.5, it doesn't drop down with engine speed.
post #4 of 29 Old 02-14-2017, 07:27 PM
Just A Guy
NAJ's Avatar
After re-reading the original post it sounds like you may have an AIS issue, either the AIS is not responding to load changes or the TB and AIS need to be cleaned.
Do you experience any similar issues when the A/C is on or the steering wheel is turned, both apply load the idle should increase to compensate.
post #5 of 29 Old 02-14-2017, 08:04 PM Thread Starter
Engine: 2.2 MPFI
CRAP!!! Sorry, just happened to her again and the voltage DOES drop down to 12 or just below and she said the dash lights DO dim. But this time when it happened the radiator fan was NOT on. I recently cleaned the TB and AIS but haven't tried a new AIS which I have. She also said once in a while it seems like it doesn't want accelerate right away from stop or idle... car has NO A/C or P.S.
post #6 of 29 Old 02-14-2017, 08:19 PM
Just A Guy
NAJ's Avatar
If you are losing voltage and the lights dim that takes us back to a charging issue again.
Did you check for any fault codes?
post #7 of 29 Old 02-14-2017, 08:40 PM Thread Starter
Engine: 2.2 MPFI
Yea, no codes :(
post #8 of 29 Old 02-15-2017, 05:49 AM
Just A Guy
NAJ's Avatar
Just to recap...
1)RPM drops momentarily with initial electrical load placed on system.
2)Battery voltage drops to 12 volts momentarily with initial electrical load placed on system.
3)RPM drops and stays low while cooling fan is on.
Questions...
1)What is battery voltage reading while the cooling fan is running and the RPM is low?
2)Exactly how low does the RPM drop with electrical load applied to system?
3)If you increase RPM to 1500-2000 and then apply an electrical load does the battery voltage still momentarily drop to 12 volts?
4)While holding the RPM steady between 1500-2000 RPM's does the RPM drop when an electrical load is applied?
Jan
1990 Daytona Shelby VNT
post #9 of 29 Old 02-15-2017, 07:28 AM Thread Starter
Engine: 2.2 MPFI
I can test the voltage/drop but this car does not have a tach so I won't know exact RPMs.
post #10 of 29 Old 02-15-2017, 06:28 PM
Just A Guy
NAJ's Avatar
I am trying to determine if this is an electrical load issue or an AIS issue so the more info you can provide the better.
Why was the alternator replaced?
Was the problem present before the battery and alternator were replaced?
post #11 of 29 Old 02-15-2017, 08:48 PM Thread Starter
Engine: 2.2 MPFI
Alternator was replaced about a year and a half ago and battery about 6 months ago. Alternator was replaced because it had a squeaky bearing, battery was replaced because it was about 7 years old and finally bit the dust do to lack of driving at that time. I'd say this issue started somewhere close to the time we replaced the battery. Back then it would also hesitate to accelerate from a stop on maybe the first 2 times of the drive, now she said it's completely random and only once in a while.
post #12 of 29 Old 02-16-2017, 06:28 AM
Just A Guy
NAJ's Avatar
Start by verifying base idle is correct and reset the AIS.
TB Cleaning, Base Idle and AIS Reset
post #13 of 29 Old 02-16-2017, 07:37 AM Thread Starter
Engine: 2.2 MPFI
I will do, and report back!
post #14 of 29 Old 02-17-2017, 08:40 AM Thread Starter
Engine: 2.2 MPFI
Ok, did the base idle / AIS reset with no luck, put the new spare AIS I had on, still no luck. It seems like all is well until idling in place for too long then gets intermittently angry..
post #15 of 29 Old 02-17-2017, 04:39 PM
Just A Guy
NAJ's Avatar
I an assuming you do not have access to a scanner so I will have to think on this.
Tags
bog , electrical , ground , power , surge
Human Verification
