No shaft play in turbo could seals still be shot? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 10 Old 03-19-2017, 12:17 PM Thread Starter
My Ride: 84 rampageT-II
I've had an oil issue for some time. Smoking. Anyway after pulling the head it's clear something is wrong with #3 cylinder. Could be valve guide. Will be taking it to the machine shop Monday. The turbo boosts strong and there is no shaft play. Could the seals still be shot? Did not notice any oil trail in the swing valve.
xtrooper is offline
post #2 of 10 Old 03-19-2017, 05:07 PM
- OFFICIAL GEARHEAD -
ILIKESHELBYS's Avatar
My Ride: SC/GLHS(2)/CSX
Re: No shaft play in turbo could seals still be shot?
The turbo is probably still good. If it was not blowing clouds of smoke, especially after the engine was hot and idling at least the piston seal on the turbine side is still good. The turbine will dump oil into the hot swing valve and create a huge cloud of smoke when the engine is at idle or as you come to a stop. That is because when you are driving there is back pressure in the exhaust and the oil stays in the turbo cartridge/housing. When you let off, the back pressure is gone and oil gets sucked or will drizzle into the hot swing valve.
Boost on...
Steven Seale
QUICK-FIT SHIFT RODS★ ~ ★A525/A555 CONVERSION BRACKET
QUICK-SHIFTER ★ ~ ★REBUILT TRANSMISSIONS★ ~ ★PT LIFTERS AND SHIMS
PROUD TO BE AN ACTIVE MEMBER OF THE TURBO DODGE ENTHUSIAST COMMUNITY
ILIKESHELBYS is offline
post #3 of 10 Old 03-19-2017, 07:06 PM Thread Starter
No clouds of smoke. It's easy to go down the rabbit hole once the head is off. Gonna let it ride as is. We'll see.
xtrooper is offline
post #4 of 10 Old 03-19-2017, 09:13 PM
Level 2 Supporter
If you change to Mobil 1, the amount of smoke will be reduced vs Dino oil. I have used this trick for over 30 years.
chromguy is offline
post #5 of 10 Old 03-19-2017, 09:55 PM Thread Starter
Been using synthetics for many years. Recently changed to Shell Rotella T6.
xtrooper is offline
post #6 of 10 Old 03-20-2017, 06:10 AM
My Ride: 86 GLHT
Engine: 2.5L
When a seal went on my SRT-4 turbo it would throw a James Bond smoke screen under boost.
Never did it when I was not boosting.
This was a big wheel stock turbo that had some machining issues.
Keith Alto is offline
post #7 of 10 Old 03-23-2017, 09:14 PM
Level 2 Supporter
My Ride: little mopars
Engine: 2.0 T (DSM), 2 x 2.5 TBI, 2.2 T1, 2.2 T2, 5.2 Mag
You mentioned #3 cylinder doesn't look right. Piston problems are somewhat common these motors. Not always as obvious as you'd think just looking real quick. Could be source of smoke and oil consumption. You might want to double check while the head is off.
AndyJ01 is offline
post #8 of 10 Old 03-26-2017, 01:36 PM Thread Starter
Got the head back from the machine shop. When I took it in and he removed the springs, one of the valve guides In #3 cylinder was extremely sloppy. Starting to put everything back together. thanks for the replies.
xtrooper is offline
post #9 of 10 Old 03-26-2017, 02:48 PM
Garrett Booster
good time to go ahead and do PT lifter upgrade and beehive springs.
masterjr3333 is offline
post #10 of 10 Old 03-26-2017, 07:02 PM Thread Starter
I did go with Ilikeshelbys pt lifters. Not racing so don't know if the beehives would be a big plus. We'll see
xtrooper is offline
Human Verification
