Vacuum Lines - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 6 Old 04-17-2017, 04:26 PM Thread Starter
My Ride: 86GLHS
Vacuum Lines
Trying to determine which type of line to use.Nylon is stock the alternative is polyurethane which has a much higher melting point.But I'm not sure about bendability?Anyone have any experience with the polyurethane tubing?Thanks
pantera74l is offline
post #2 of 6 Old 04-17-2017, 07:18 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
Re: Vacuum Lines
poly has a lower melting point but greater "bendability" I use poly on all my stuff, and all my friends stuff. The only time I've had an issue with it is when it touches the cylinder head on a 95+ degree day. As long as I keep it away from the cylinder head it works great.
Poly Temp. Range
-40F to +160F
(-40C to +71C)
polyurethane (PUR) tubing is strong, flexible, and offers superior kink resistance.
Nylon Temp. Range
-60F to +200F
(-51C to +93C)
Nylon tubing is used for applications which require higher pressures and superior heat/chemical resistance. It is somewhat less flexible than PUR, but is strong, lightweight,
GLHNSLHT2 is offline
post #3 of 6 Old 04-18-2017, 11:55 AM Thread Starter
My Ride: 86GLHS
Re: Vacuum Lines
You're right(lol) I didn't have my reading glasses on.I thought 500 was melting point.....it actually was 500' rolls.Thanks
post #4 of 6 Old 04-19-2017, 03:23 PM
TD Extreme User!
My Ride: 90 Daytona Shelby
Images: 12
Garage
Re: Vacuum Lines
For soft lines, I've been using Neoprene rubber and/or silicone lines. Neoprene is good into the low 200s F. Silicone is much higher (200's C). Neoprene is fairly firm but still flexible. Silicone is very flexible so you have to use thicker walled stuff to keep it from balooning/collapsing and kinking. Both are easy to come by through industrial supply houses, etc.
For hard lines, Nylon works fine. There is also Acetal, which is very similar to Nylon.
EvilcowRoland is offline
post #5 of 6 Old 04-19-2017, 10:04 PM
- OFFICIAL GEARHEAD -
ILIKESHELBYS's Avatar
My Ride: CSX/CS/GLHS
Re: Vacuum Lines
I always use Nylon hose which is also commonly used in air brake applications. It is high pressure rated, has excellent hi-temp, oil resistance and is quite flexible. Available in a variety of sizes, I have completely rebuilt TI and TII vacuum harness cars with this stuff. It's great for turbo cars where engine heat is a major issue over the intake where temps frequently get to 200*F or more. At these higher temps the inexpensive PVC (poly) hose commonly sold at the auto parts store easily melts. The poly hose is typically not the emmissions grade hose that they also sometimes sell in a blister package or plastic bag, like 3' at a pack. That is or should be vinyl hose.
I get my stuff at: EVCO House of Hose in Salt Lake City, UT
You can get it almost anywhere they sell air brake tubing...like: Hose and Fittings, Etc | Parker hydraulics & pneumatics in CA & NV
It is also easily found on eBay...it's made by Edelmann
Summit Racing sells it but its special order
Just search eBay or Google for "PFT-4A"
The PFT part is the type of hose, there is type 'A' and type 'B'. You want type A. The reinforced type 'B' actually has a lower burst pressure....but it's still something like 1200PSI.
Parflex Tubing (PFT) Nylon tubing designed for use in tractor, trailer and other mobile air brake, instrumentation and air accessory systems.
Meets SAE specification J844 Type A or B, D.O.T. FMVSS106, and performance requirements as specified in SAE specification J1131.
Heat and light stabilized seamless single wall extruded nylon tubing, available in sizes 1/8 (-2), 5/32 (-2.5), 3/16 (-3), 1/4 (-4) and 5/16 (-5).
This tubing conforms to SAE specification J844 type A.
The A refers to non-reinforced tubing.
Temperature Range: -40F to +200F (-40C to +93C).
Maximum Working Pressure: 150 PSI.
Meets D.O.T. FMVSS 106 (Sizes 2 and 2.5 not listed in FMVSS 106).
The sizes that I typically order are:
PFT-4A (1/4) / Nylon air brake tubing black @ $.47/ft. I buy 10' at a time or more
PFT-2.5A (5/32) / Nylon air brake tubing black @ $.72/ft. I buy 10' at a time or more
Boost on...
Steven Seale
QUICK-FIT SHIFT RODS★ ~ ★A525/A555 CONVERSION BRACKET
QUICK-SHIFTER ★ ~ ★REBUILT TRANSMISSIONS★ ~ ★PT LIFTERS AND SHIMS
PROUD TO BE AN ACTIVE MEMBER OF THE TURBO DODGE ENTHUSIAST COMMUNITY
ILIKESHELBYS is offline
post #6 of 6 Old 04-20-2017, 06:57 PM
Legendary Driver
GLHNSLHT2's Avatar
Re: Vacuum Lines
Steve, just and FYI for your future purchases and since this subject is spanning 2 different websites and multiple threads
https://www.automationdirect.com/adc...bing_-a-_Hoses
They have both nylon and poly.
bend radius on poly is .2" and nylon is .5"
Full specs can be found on that site
Along with a 10.5 cents per foot price on 5/32 line and 19 cents per foot on the 1/4 line
I prefer the poly over the nylon. I do every turbo car I run across in it. The nylon get's hard and brittle with heat as seen in our cars with factory nylon tubing. I also have super tight bends on some of my lines. If you have air around the poly (i.e. not touching your 180+ degree cylinder head) they never melt and remain flexible over the long haul. But with rolls at that site being so cost effective I guess you could just rebuild the harness every few years :)
Pics of some of my vac harness'
Before:
After:
Full factory 88 T2 harness before selling the car.
And the way I like to run my 2 piece setups. Notice the tight bend to the FPR
Human Verification
